Honda S2000 oil starvation/ main engine bearing problem
Old Sep 29, 2005 | 11:30 PM
Gary Peiffer
Guest
Posts: n/a
Hi folks,
I was considering buying a 2000 or 2001 Honda S-2000, but then a mechanic told me about the 'dirty little secret' some of the earlier models of the S-2000 had. Honda eventually fixed it in later models, but it was an "oil starvation" problem in earlier models and it could cause problems with the main bearing of the engine... which could get very expensive. I am interested in hearing accounts or stories from people who have had this problem with an S-2000. Did it occur rarely? Moderately often? How expensive were the repairs? How good was Honda about the problem? I was told by the mechanic that there's no way to diagnose this problem in a car that has it. Would you recommend (or advise against) a 2000 or 2001 S-2000? What model year was it when Honda had this problem fixed for good? Did the problem occur in the 2002 model also? Thanx for any info.
G. Peiffer
Alameda, CA
Old Sep 30, 2005 | 12:31 AM
SoCalMike
Guest
Posts: n/a
Re: Honda S2000 oil starvation/ main engine bearing problem
Gary Peiffer wrote:
> Hi folks,
no ones posted here about it that i can recall. your best bet would be
s2000 forums, and/or google.
Old Sep 30, 2005 | 01:30 AM
jim beam
Guest
Posts: n/a
Gary Peiffer wrote:
> Hi folks,
> G. Peiffer
> Alameda, CA
never heard of it. doubt it very much. and there's five main bearings,
not just one.
Old Sep 30, 2005 | 07:50 AM
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:yamdnQrl_tgAWqHeRVn-tQ@speakeasy.net:
> Gary Peiffer wrote:
>> Hi folks,
<snip>
> bearings, not just one.
It seems different oil jet bolts were installed as of May '02 to address
potential oil starvation issues under very heavy loads. There's a TSB on
this. Hardly a "dirty little secret".
A bit of Googling turned up this, with much stellar info:
http://www.s2ki.com/forums/index.php?showtopic=138344
And from The Temple of VTEC:
http://tinyurl.com/7mwrm
Photo sequence of the repair:
http://www.pbase.com/rsrock/oil_jet_bolt_replacement
Another discussion thread:
http://www.s2ki.com/forums/index.php...f=123&t=162487
TeGGeR®
www.tegger.com/hondafaq/
Old Sep 30, 2005 | 10:34 PM
Gary Peiffer
Guest
Posts: n/a
Excellent answer. Thanks for all the information.
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns96E146D98754Etegger@207.14.113.17...
>> Gary Peiffer wrote:
>>> Hi folks,
> <snip>
> TeGGeR®
Old Oct 1, 2005 | 04:30 PM
azz84932
Guest
Posts: n/a
On Thu, 29 Sep 2005 20:32:07 -0700, SoCalMike
<Mikein562athotmail@hotmail.com> wrote:
>Gary Peiffer wrote:
>> Hi folks,
Have you tried here?
Old Oct 1, 2005 | 08:36 PM
jim beam
Guest
Posts: n/a
>>Gary Peiffer wrote:
>>>Hi folks,
> <snip>
i don't see a problem - i just see bleating about what /could/ happen.
i'm with honda on this one - you're never going to be able to run the
vehicle hard enough long enough for this to be an issue. especially not
if you use a decent oil.
Old Oct 1, 2005 | 10:34 PM
TeGGeR®
Guest
Posts: n/a
news:3LudnWX5IpWmt6LenZ2dnUVZ_s-dnZ2d@speakeasy.net:
> not if you use a decent oil.
It says in the one thread that the oil starvation issues are happening to
cars subject to very unusual loads, such as being driven for 120mph for a
half-hour. And even then it's not *all* cars driven that way that
experience the problem, but only a few. There are almost no reports of such
failures in North America.
It's a pretty minor issue overall. That still does not stop some from
declaring darkly that Honda has a "dirty little secret". What a joke. I
guess the conspiracy theorists have to have *something* to believe in,
don't they?
TeGGeR®
jim beam
Guest
Posts: n/a
> don't they?
so true.
Old Oct 2, 2005 | 01:30 AM
FanJet
Guest
Posts: n/a
>> happen. i'm with honda on this one - you're never going to be able
>> to run the vehicle hard enough long enough for this to be an issue.
>> especially not if you use a decent oil.
> happening to cars subject to very unusual loads, such as being driven
> for 120mph for a half-hour. And even then it's not *all* cars driven
> that way that experience the problem, but only a few. There are
> almost no reports of such failures in North America.
Oil starvation is much more likely related to engine speed and lateral
loads, not road speed.
> I guess the conspiracy theorists have to have *something* to believe
> in, don't they?
I think it's reasonable to expect no oil starvation issues with a US$ 30K+ 4
cylinder engine equipped car that's advertised as designed to be driven very
hard.
Old Oct 2, 2005 | 10:43 AM
TeGGeR®
Guest
Posts: n/a
"FanJet" <FanJet27@hotmail.com> wrote in
news:JoJ%e.383$PA1.44915@monger.newsread.com:
You've not read the links given in earlier messages, that's clear.
The oil starvation has to do with the oil spray pattern applied to the
cylinder under the piston. Starting May/02 Honda replaced the older 2-hole
oil-jet bolts with ones that have 4 smaller holes to address this issue.
Apparently the four smaller holes give a better spray pattern for high
engine speeds.
>> in, don't they?
> 30K+ 4 cylinder engine equipped car that's advertised as designed to
> be driven very hard.
Nobody's perfect of course. Automakers discover this sort of glitch
regularly, which is the very reason TSBs and warranties exist.
Speaking for TSBs, a kind contributor just emailed me a bunch more TSBs for
addition to the TSB page.
TeGGeR®
Old Oct 2, 2005 | 11:34 AM
jim beam
Guest
Posts: n/a
> engine speeds.
and i guarantee, 4 small holes will clog /way/ more easily than 2 larger
ones. i return to my previous comment - using decent oil is critical.
at a slight tangent to that, if just one piston at the end of the block
is experiencing this problem, it's likely a coolant circulation issue
more than an oil issue. but addressing that would require a whole motor
redesign. some mods like gasket hole changes can help, but coolant
circulation is just about the least refined aspect of most cars simply
because most vehicles don't get worked hard enough for it to be a
problem. i recall one instance where a block assembly that had been
used by a certain manufacturer had successfully worked on gasoline
engines for over 30 years, but when that motor was used as a base for a
diesel derivative, it would consistently burn out one piston at the far
end of the bank. essentially, a coolant circulation issue that had
always been present but "not serious" was now exposed under the much
harsher higher temperature regime of diesel operation.
it's an interesting problem. circulating coolant from one end to the
other is cheap, convenient & works, but by definition, coolant at one
end is going to be warmer than the other. it can be addressed with
"cross flow" cooling, but that means separate liners, a longer heavier
block, and mechanical stability issues that mean yet more weight. is it
worth the trouble for a motor that in all other respects and
applications is quite exemplary except when experiencing *uninterrupted*
maximum output for more than 30 minutes? there aren't many places where
you're going to start to get close to that ceiling, even on a track.
>>>in, don't they?
Old Oct 2, 2005 | 04:31 PM
TeGGeR®
Guest
Posts: n/a
news:T6GdnVTFKY0hbqLenZ2dnUVZ_s2dnZ2d@speakeasy.ne t:
<snip>
> is
> it worth the trouble for a motor that in all other respects and
> *uninterrupted* maximum output for more than 30 minutes? there aren't
> many places where you're going to start to get close to that ceiling,
> even on a track.
It happens in Europe, which is why the TSB has not been issued for North
American cars. Europeans tend to drive at much higher speeds than we do.
North American cars are more likely to sludge up, on account of our driving
and maintenance patterns.
TeGGeR®
Old Oct 2, 2005 | 10:34 PM
jim beam
Guest
Posts: n/a
> <snip>
>>is
>>even on a track.
only on german autobahns. everywhere else is speed limited & strictly
enforced from what i saw.
inferior oil formulations a much more likely cause.
Old Oct 3, 2005 | 02:30 AM
TeGGeR®
Guest
Posts: n/a
news:6Iedne2WmNQkCd3eRVn-jA@speakeasy.net:
>> North American cars. Europeans tend to drive at much higher speeds
>> than we do.
According to my sister, who has driven in Holland and Belgium, speed limits
there are sort of theoretical.
Britain is a different story, on account of their photo radar.
>> driving and maintenance patterns.
Inferior maintenance practices as well. When Toyota's 1MZ-FE engine sludge
problems began to surface a few years ago, Toyota discovered the problem
existed primarily in the US, with very few cases in Canada. Their research
indicated that more Americans than Canadians lease instead of own, and
lessees are *much* less likely to pay attention to maintenance than owners.
And speaking of maintenance, I wished so bad today that I had a garage.
There's a '94 Caravan for sale down the road from me. It's in wonderful
shape, straight, rust-free body, and is going for $450. The only problem? A
blown head gasket. But I've got no place to keep it. If only...
TeGGeR®
Old Oct 3, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
>>>than we do.
you should buy the caravan and do the gasket just for the sake of it.
you'll be /so/ glad for the reality check on how well honda make cars
compared to that, er, "thing".
Old Oct 3, 2005 | 01:30 PM
dold@XReXXHonda.usenet.us.com
Guest
Posts: n/a
That would have to be since my last visit there.
The M4 has some nominal limit, but the cruising speed from Bracknell to
Windsor seemed very stable at 100mph, in traffic.
I was a passenger in a Renault of some diminutive size, and that seemed
like about 25 too many mph for me, and the engine.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8,-122.5
Old Oct 3, 2005 | 10:30 PM
Gary Peiffer
Guest
Posts: n/a
The phrase "dirty little secret" did not originate with me. If you go into Google search engine, and search on the keywords S2000 oil starvation, look at the second hit out of 552 hits. It jumps right out of your computer monitor screen and right into your face. The link is at http://www.solsticeforum.com/forum/s...p?t=664&page=2
and the comments were:
Originally Posted by Chip
JB; I too wanted an S2000 since it was a new model in 00. My first issue was the plastic rear window which was changed to glass in MY 02. The second reason was the "market value scalding" dealers were adding to the bottom line. I almost bought an 02, but the second gear issue was still a problem to many owners and there was a dirty little secret about a short block oil starvation problem that several owners experienced and had to have the short block replaced and in the hands of "ham fisted" techs. for long periods of time. While the cars waited on parts many owners cars suffered mild body damage that dealers claimed they were not responsible for. I must say in all fairness that the above issues may have only happened to a few owners, but you need to know about them. Additionally there were power window (power down) issues, rear diff. issues and a few other small issues that all conspired to make me look elsewhere for a ride. I must also say that many of the above issues may have been caused by hard spirited driving as well, but that's why folks buy cars like this is it not? My advice to you is to wait until we see what Mr. Lutz & Co. offers up and then decide which car is best suited for you. Good luck!
"TeGGeR®" <tegger@tegger.c0m> wrote in message news:Xns96E2DDDBBAF16tegger@207.14.113.17...
> don't they?
> TeGGeR®
Old Oct 3, 2005 | 11:30 PM
TeGGeR®
Guest
Posts: n/a
"Gary Peiffer" <garypeiffer@sbcglobal.net> wrote in
news:Ajl0f.8609$oO2.5786@newssvr27.news.prodigy.ne t:
Never said it did. I never said WHO said it.
TeGGeR®
TuLaLiT
Sep 20, 2013 12:16 AM
Sky75
Apr 21, 2011 05:42 AM
bennifer
Aug 16, 2010 11:37 PM
gmbdelsol
Apr 12, 2010 08:33 PM
daggonit
May 1, 2008 07:11 PM
