95 H22A Problem
Old Oct 7, 2005 | 08:30 AM
Ross Cranford
Guest
Posts: n/a
95 H22A Problem
I've got a 95 H22A and it has an intermittent problem where it "Spits &
Sputters" from time to time. There are times the car is great and there are
other times when I press on the gas and the RPM's decrease instead of
increase, or accelerates very slowly with "misfire" happening quite bad.
To try and redeem this problem I've tried installing new NGK Iridium spark
plugs, MSD Plug Wires, New Cap & Button, Converted to External Coil,
Installed an EGR blocking plate, and a new O2 Sensor.... and guess what,
it's still the same.
Any ideas what to try next or suggestion of things to try?
Thanks,
Ross.
Old Oct 9, 2005 | 12:33 AM
Jason
Guest
Posts: n/a
Re: 95 H22A Problem
In article <9bt1f.105415$Ph4.3209444@ursa-nb00s0.nbnet.nb.ca>, "Ross
> Thanks,
> Ross.
Ross,
I will make a guess--
Dirty or defective fuel injectors. There should be a procedure for
checking them in your repair manual. If they are dirty, a can of injector
clearner (added to the gas tank) should solve your problem.
Jason
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
iforgetus
Nov 26, 2019 08:54 AM
ikutoisahobo
Oct 2, 2019 01:58 PM
$p!@t1027
Apr 13, 2014 04:33 PM
CTCT
Nov 26, 2012 10:00 PM
Kholland
Nov 10, 2011 05:16 PM
