Tire Pressure Monitor
Old Sep 3, 2008 | 09:36 PM
ChefMark's Avatar
My Tire Pressure monitor light is on. I have checked all the tire pressures and they are all at 32psi. Has anyone else had this problem
Old Sep 3, 2008 | 09:41 PM
Firebat666's Avatar
just wondering... is the pressure gauge your using good quality? if not that could be your problem
Old Sep 3, 2008 | 09:48 PM
ChefMark's Avatar
Yep, it is a good one not one of those dtick type
Injundon's Avatar
odd but necessary quetion hwere..are you still using th OEM rims?
Old Sep 3, 2008 | 09:51 PM
ChefMark's Avatar
Good question, yes everything is still OEM.
Old Sep 3, 2008 | 09:54 PM
Injundon's Avatar
Take it to the dealer.. this can happen after rotating your tires, or if a clip came loose, tire pressure anywhere from 28PSI-35PSI should not register any faults.
Old Sep 3, 2008 | 09:56 PM
ChefMark's Avatar
Yea, I set up a time to take it in the only wat to find out
Old Sep 3, 2008 | 10:22 PM
sprint7677's Avatar
I run 38 psi, my light recently came on when one tire (right rear) pressure got below 28psi
Old Sep 4, 2008 | 01:34 PM
ChefMark's Avatar
Going to work this morning and the light went off. It must take a few minutes/miles to reset.
Old Sep 4, 2008 | 01:57 PM
Tofuman's Avatar
The light with the tire and "!" means that the system is registering a flat tire, if it's the "TPMS" light, it means there is a problem with the tire pressure monitoring system itself.
Old Sep 5, 2008 | 02:06 PM
stickyricebandit's Avatar
that light come on one morning before i left for work. checked it out and drove off (i was running a bit late to check the pressure) After work I went to go home and the light was no more
Old Sep 5, 2008 | 02:36 PM
Super Mario's Avatar
Might have something to do with the time of day and the heat of your tires. In the morning it's cold and your tires are cold. In the afternoon, you've driven your car home + it's warmer so your tires probably expanded.
Since the light came on in the morning my best guess is that your tire pressure COLD is too low. Might need to inflate them a bit.
japspeed
Apr 11, 2014 09:29 AM
eggyacid
May 4, 2012 03:58 PM
Tounge73
Dec 15, 2008 09:13 PM
hollins2007
Dec 11, 2008 09:34 PM
RichXKU
Sep 29, 2008 07:26 AM
