Starting problem in 89 Civic LX
Old Oct 11, 2005 | 04:32 AM
mmdir2005@yahoo.com
Guest
Posts: n/a
Is bad alarm system causes the major starting problem?
For the first time in 2 or years, the engine turned over
the first time I turned the key. I did not wait for car to cool down.
It started right on first since I discovered the electrical problem on
alarm system. But I don't know if this is the only problem. IN the
past, I suspected the problem on starter, main relay, bad ignition,
batter, distributor and/or battery. I replaced battery and main relay.
3 days ago was a worst starting trouble I had, to wait for 3 hr to
start the car. Then next day, I discovered a electrical problem on
alarm system. I want to remove the whole alarm system including all the
wires. I don't know how.
The problem of alarm also seems to cause other problem.
The amplifier is receiving sometimes a less current that output is
weaker than a normal I suspect this is caused by the electrical
problem on Alarm system.
Old Oct 11, 2005 | 09:30 AM
Burt Squareman
Guest
Posts: n/a
Re: Starting problem in 89 Civic LX
<mmdir2005@yahoo.com> wrote in message news:1129016573.648343.172860@f14g2000cwb.googlegr oups.com...
Sounds like it doesn't crank. This is probably due to the alarm relay
installed on the vehicle. Either bypass the alarm's relay or
disconnect the alarm fuse. Most alarm manufactures allow the car
to return to it's normal state when the alarm's fuse is removed. This
allows you to diagnose the problem based on factory procedures.
FitfulKenny
May 5, 2015 12:11 PM
its.ryu
Apr 26, 2009 10:14 PM
cph81
Feb 21, 2008 07:48 PM
zz1800@gmail.com
Sep 25, 2005 09:30 PM
toypup
Sep 21, 2005 08:31 PM
