LED T/Ls in, CC goes south
Old Sep 17, 2008 | 04:42 PM
avcm's Avatar
Bought and installed Wheels & Grillze JDM LED Tail Lights. Same as original except for LED Stop and Tail. Looks good, works great....except....
Driving on a trip this past weekend using CC, it gets dark, turned the lights on and... CC drops out and CC light goes out. CC Main still on, CC will not set.
Today disconnected the T/Ls, turned on lights and CC worked just fine.
08 FIT Sport, MT, just at 1000 mi.
HELP!!!!!(please)
Old Sep 17, 2008 | 04:57 PM
seeremlive's Avatar
One of two things.
One: If these are not plug and play (meaning they had the proper plugs and the proper length wire) make sure you are not feeding voltage from the tail light back to the brake light circuit. This will cause the computer to think your foot is on the brake and turn off the CC.
Two: If you are sure number one is not it, most likely you need some additional resistance in the hot lines of the break lights (and mostlikely the tail lights to make the flashers work properly). Real bulbs pull more power than LED. An easy fix.
Stop by your local parts store (I know Autozone has what I am talking about) and in the light and fuse section right next to the replacement LED bulbs they have ceramic resisters that will add the additional load that the rest of the electrical system is looking for.
This and flasher problems are the most common problems with LED lights in a car that was designed for real bulbs.
Last edited by seeremlive; Sep 17, 2008 at 05:00 PM. Reason: added another thought
Old Sep 19, 2008 | 10:33 AM
avcm's Avatar
Thumbs up Thanks for the help, should solve the problem.
Thank you!!
Old Sep 22, 2008 | 11:42 AM
Rod2Rice's Avatar
You also may need to wire in some diodes to get the problem fixed. I know I had to do that with my LED tails. When I would step on the brakes the front marker lights would come on.
Old Sep 22, 2008 | 08:55 PM
seeremlive's Avatar
Good tip this would ensure that there is no voltage back fed to the brake light and thus the CC circuit. +1
Old Sep 22, 2008 | 09:00 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I barely know what was going on due to abbreviations. Glad its fixed though?
Old Sep 22, 2008 | 09:24 PM
seeremlive's Avatar
Judging from the avatar he is Navy. You know how the Military is. It's alphabet soup.
I don't know if it is fixed. AVCM? Any update?
Old Sep 23, 2008 | 03:47 PM
avcm's Avatar
Still in limbo, have not put in diodes/load resistors yet. I'm leaning towards the resistors first as it is an easier task. The MAF is still on the board in the AWP pocket
Old Sep 23, 2008 | 03:55 PM
Rod2Rice's Avatar
Load resistors are only needed if the turn signals are LEDs, if the turns are regular bulbs then you are fine. Sounds like you need the diodes.
Old Sep 28, 2008 | 07:31 PM
LaoSiFu's Avatar
Rod2Rice, if you don't mind can I see a picture of your Fit rear? I have been curious about those tail lights.
~Robert
Old Sep 28, 2008 | 11:42 PM
Rod2Rice's Avatar
Sure thing!
Old Sep 29, 2008 | 02:45 AM
LaoSiFu's Avatar
Thanks I have been wondering how they look in person. Especially the black housing too.
~Robert
Old Oct 4, 2008 | 04:09 PM
avcm's Avatar
Bought the load resistors but have not installed them. Anyone know what size (amperage) diodes to install?
PS: please don't hijack the thread.
Stephen Lawson
Mar 12, 2021 12:20 PM
stryan
Aug 3, 2011 06:14 PM
InternDoc
Aug 1, 2011 10:34 PM
Cat
Jul 1, 2011 06:15 AM
FELIXY69
14
Jan 5, 2008 03:49 PM
