IAT question
Old Oct 10, 2008 | 07:54 PM
Nighthawk_GD3's Avatar
Exclamation IAT question
Question. What would happen if i didnt use my IAT? My iat is too far away to connect to the wires. And i have no way of getting to radio shack to get some more wire and solder. Would i be ok having it unplugged for just a short amount of time?
Old Oct 10, 2008 | 08:40 PM
manxman's Avatar
Probably you'll be OK. Other posters have found the IAT sensor just hanging loose after a service appt., had no CEL's, car ran fine, plugged it back in and all was well.
Old Oct 10, 2008 | 08:49 PM
Injundon's Avatar
you will possibly run lean in cold weather and will run a little rich when it's really hot.
Old Oct 11, 2008 | 07:49 PM
DOHCtor's Avatar
The hotter the air the IAT sees, the lesser the fuel is gonna be injected and the PCM's gonna pull back timing also!!
Marko!!
Old Oct 14, 2008 | 05:56 PM
DOHCtor's Avatar
Ok i did tests with my scan tool!!!
59°f Intake air = 15° timing at 6000Rpm at full load!!
82°f Intake air (let the sensor in the engine bay!) = 12° at the same 6000Rpm... not to mention that the engine felt more lazy... all tests were done with 92 Octane Irving premium to eliminate possibilities of pinkage and the knock sensor going nutz!!
Marko!!
Myxalplyx
Sep 27, 2014 11:31 AM
archangel1177
Mar 23, 2012 06:22 PM
Fieldstone
Aug 15, 2011 07:07 PM
mhopper
Mar 9, 2011 08:34 PM
Fit of RAGE
19
Apr 20, 2008 12:53 PM
