suggestions on side mouldings
Old Dec 25, 2005 | 10:21 AM
pfx's Avatar
pfx
ey guys imo removing the side moldings of the jazz would give it a slick look.whatcha think?im thinking of removing mine.thanks
Old Dec 25, 2005 | 05:12 PM
vividjazz's Avatar
Someone that Posts too much
All the Jazzes sold in Australia come without any side moldings. If you want to see how it would look check out the Australian Honda Jazz site or any of the very many online Australian reviews of the Jazz over the years (since 2002). www.honda.com.au/jazz
Old Dec 25, 2005 | 09:55 PM
discoburg's Avatar
The Jazz and Fit sold in Singapore also do not have the side mouldings. With it the Jazz/Fit does not look that aerodynamic.
Old Dec 26, 2005 | 03:59 PM
pfx's Avatar
pfx
thanks vividjazz
i was thinking of removing mine but the double adhesive might leav a mark on the paint job which canot be removed by sanding and buffing i dont want to repaint the foor door panels.
anybody ever did this?whats your experience
Old Dec 26, 2005 | 06:08 PM
vividjazz's Avatar
The goop left by the tape would be similar to the goop you have left over when removing badges / stickers.
If you use fishing line and a hairdryer (hot air gun if your a blokey bloke that won't admit to using your gf/wifes hairdryer) you can work the adhesive off pretty well. Heat causes it to be less sticky.
The panel shops use either diluted paint thinner (make sure to test on a unseen part of the car 1st) or a special remover which feels oily called de-solve-it which can be purchased from auto shops.
You'll need to polish and wax the area afterwards regardless of the method employed.
Old Dec 27, 2005 | 02:07 PM
Jonniedee's Avatar
What Vivid said plus Goo - Gone or WD40!!!
Old Dec 27, 2005 | 03:15 PM
SilverNChrome's Avatar
2 words to consider before you do this....DOOR DING!!!!!
I don't know about the Phillipines, but here in the U.S. we have a lot of inconsiderate wankers that will throw open their doors in a parking lot without any concern for your car parked next to theirs.
I think the smooth look is great....just be careful where you park!!!!!
Old Dec 28, 2005 | 04:25 AM
pfx's Avatar
pfx
tried removing it bu theres two holes for the clips each door panle.decide not to as i have to repaint the doors and fill the holes
Old Jan 26, 2006 | 08:06 AM
ekek888's Avatar
myx is doing exactly this. there are about 7 holes total. you have to epoxy to cover the holes and hammer it in when it hardens so its not higher than the rest. putty and sand till flat perfect. u have to putty and sand several times.
go to body shop and have it done if ur inexperience.
Old Jun 6, 2006 | 01:01 AM
LiL Wee FIT's Avatar
Where else do the FIT/Jazz come standard with door mouldings, aside from the Philippines?
Vance
Oct 11, 2008 01:14 PM
accordguyintake
Aug 26, 2007 11:51 PM
Zika Mashina
May 10, 2006 08:55 PM
Reality
Mar 29, 2006 01:19 AM
pappiccio
Dec 9, 2005 01:28 PM
