Jazz engine noise
Old Jan 2, 2006 | 02:48 PM
tanker's Avatar
Angry Jazz engine noise
I have a jazz automatic. At 6500 miles I noticed a noise at 1100 revs. This was only when under loar and in first gear. I went to a dealer. They tetsed it and eventually agreed ther was anoise. they said it was engine resinence. ther was nothing that could be done. I do not agree. Honda built a fine car and they build brilliant engines. So why cant this be fixed. Does anyone else have the same problem??
Old Jan 2, 2006 | 04:20 PM
vividjazz's Avatar
Someone that Posts too much
It most certainly can be adjusted and fixed. You should contact Honda UK if the Honda dealer won't honour the vehicles warranty. Dealers must be the same the world over.
Old Jan 2, 2006 | 06:20 PM
ahcow's Avatar
what sort of noise you are talking about? high pitch whining noise? Tapping noise? squealing noise? Are you sure it is from the engine and not the CVT?
Old Jan 3, 2006 | 04:24 AM
tanker's Avatar
Hi,
Thanks for the reply. The noise I think is from the gearbox. At 1100 revs it gives a sound like the exhaust blowing. It omly lsats a moment. It is vey noticable in 1st and reverse gears.
Old Jan 3, 2006 | 11:20 AM
Volk's Avatar
Hi Tanker,
If you have the CVT you might want to check out this thread.
https://www.fitfreak.net/forums/fit-diy-repair-maintenance/3155-cvt-vibration-help.html
talks about several other Fit owners who have had a CVT vibration. Seems a transmission fluid change fixed it right up.
Also you can give it a read and see if your symptoms are similar.
Old Jan 3, 2006 | 12:05 PM
tanker's Avatar
Hi mate,
Thanks for the information. I have again contacted my dealer who have just had a supply of a new type of oil for the CVT. They are going to change the oil and see what the effect is. The technician who came out with me did hear the noise. If the new oil works the will also replace the oil in 2 other Jazz's who's owners have had the same problem. It seems to me that this is a known problem that dealers only sort out if people are persistant.
Thanks
Old Jan 3, 2006 | 12:26 PM
Volk's Avatar
Good to hear they are working on it.
Let us all know how it turns out after they run the new fluid through it.
And I wish your Fit a speedy recovery.
Old Jan 4, 2006 | 10:49 PM
ahcow's Avatar
Originally Posted by tanker
Hi mate,
Thanks
Do you know which oil did they change it to?? Is it this one?
Old Jan 5, 2006 | 02:28 AM
tanker's Avatar
oil
Hi mate,
No it was not this type of oil. they tell me my Jazz has the Honda oil. However honda have a new oil out which is designed to stop gearbox noiseaand clutch slip. I will know on friday when they do the oil change. Will keep all informed of the result..
Take care.
Pete
sunnyday
Aug 5, 2017 01:51 AM
Rnak5
Jul 15, 2016 12:16 PM
Mister Coffee
Nov 27, 2014 10:29 AM
vaah
Jun 23, 2014 04:49 AM
