ETCS Learn Procedure
Old Oct 23, 2008 | 01:32 AM
DOHCtor's Avatar
Can we do the ETCS Learn Procedure without having a Honda Scanner? The reason for this is that i have forgotten the dome light on and that completely drained the battery and now i have a persistent MIL on and i think it's because of that... and if not, how much does it cost to reset it?
Marko!!
Old Oct 23, 2008 | 01:57 AM
kylerwho's Avatar
spoon fed
cant you just recharge the battery and then unplug your battery for 15 seconds to reset the ecu and your light will go away?
Old Oct 23, 2008 | 02:02 AM
DOHCtor's Avatar
Well, actually, i removed the battery from the car for a night and charged it and now i have that check engine light... the car will idle at 1000 - 1100Rpm and then got to something like 1500 - 1600rpm and that nasty MIL light will light up like a B*t*h... when it's on drive, it will never occur BTW, only when it's hot and on park or neutral...
Marko!!
Old Oct 23, 2008 | 02:13 AM
kylerwho's Avatar
spoon fed
hmmm... i dont think i can help because i have an mt. maybe try unplugging the batt for 5 min so the ecu has plenty of time to reset. not sure what else you can do.
Old Oct 23, 2008 | 11:37 AM
tougerunner86's Avatar
I left my dome light on for a week straight. (Im at college and only use the car on the weekends.) and I have no light or any problems whatsoever
Old Oct 23, 2008 | 11:42 AM
DOHCtor's Avatar
well... my fit is bizzare then...
Marko!!
Old Oct 25, 2008 | 06:40 PM
DOHCtor's Avatar
The damn code is P2101.... Anyone else got this and\or know how to repair it??
Marko!!
Old Oct 26, 2008 | 12:59 PM
shazaam's Avatar
hit up advanced or napa I think also does free scans n stuff...?
Old Oct 26, 2008 | 01:32 PM
ricohman's Avatar
Marko!!
If you don't have access to a scanner try an auto parts store.
Often the will let you scan it or scan it for you in the parking lot.
I've done this a few times with different cars and trucks over the years.
Old Oct 26, 2008 | 02:53 PM
The BOM's Avatar
wish i had alldata at my fingertips, but a google search will do
p2101
Powertrain: Throttle Actuator Control Motor Circuit Range/Performance
Sounds like a Throttle control issue (duh)
As for a relearn procedure... i doubt advance or napa or whoever can do it. Usually adaptations are MANUFACTURER SPECIFIC. A universal scan tool wouldn't be able to perform an adaptation.
Old Oct 26, 2008 | 05:14 PM
ricohman's Avatar
All an auto parts store can do is tell you the code and reset it.
I've had my battery drained a couple of times without trouble.
I've also disconnected a few times without any trouble.
Some newer vehicles have it in the manual that you have to connect the battery, apply the ebrake, run it in neutral for 2 min then back to park and off to relearn the idle.
I would be asking the dealer. Warranty?
Old Oct 26, 2008 | 06:11 PM
DOHCtor's Avatar
I have a scan tool, P2101 is my code... The car will run well at 1000rpm and then it will get to 1500rpm by itself... floor it when it happens and it won't go past 2800rpm... restart the car and it will get to fuel cut... It only happens when in park and neutral and when the car is hot... when it's in gear, it doesn't happens...
any Honda gearheads??
Marko!!
Old Oct 26, 2008 | 06:16 PM
kylerwho's Avatar
spoon fed
Old Oct 26, 2008 | 06:20 PM
DOHCtor's Avatar
Yeah, i allready tried to do that! I unplugged the battery for about an hour and then i did the whole procedure but the check engine had lit and the rpm climbed to 1500, rendering the whole procedure useless...
Marko!!
Old Oct 26, 2008 | 06:26 PM
kylerwho's Avatar
spoon fed
hmmm...... maybe try disconnecting the top o2 wire that is connected to the header because this makes the ecu run with a neutral a/f ratio and see if idle stabalizes. then plug it back in and unplug the batt and wait for awhile then start her up and see if that works.
fr8train
Dec 31, 2020 07:19 PM
crunchie
Jan 31, 2019 03:31 PM
k3uns
Jun 13, 2012 01:00 PM
rekcah
Honda Fit Dealer Reviews
Jan 3, 2011 03:33 PM
