ipod cable center console
Old Oct 23, 2008 | 12:24 PM
AlphaQuad's Avatar
Hi guys, I was thinking on getting a JDM center console and then run my ipod connection cable from my headunit under the console and have it come through the armrest box do guys think its possible? T think it would look very clean.
Old Oct 23, 2008 | 01:05 PM
Fit_to_be_tied's Avatar
if the cable is long enough it will work, i have the console and there is more than enough room fo a cable. the only issue i can forsee is the size of the hole needed to get the cable through into the box. the best i can think of so you dont get too much falling through is to drill a hole just the size of the cable, not big enough for the docking end just the wire, then cut on each side and bend the plastic so you can pass the dock end through and then the plastic should snap back together leaving just the hole for the wire.
minminmusic
May 20, 2017 10:44 AM
saiko
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 13, 2015 11:52 AM
damatick
May 26, 2011 10:56 PM
modfit669
Sep 11, 2008 06:25 PM
InigoMontoya
Mar 13, 2007 09:11 AM
