Playing AAC Files from Thumbdrive in the 09 Fit Sport
Old Nov 12, 2008 | 08:38 PM
HarrisonGreeleyIII's Avatar
The manual states:
"The audio system reads and plays
the audio files on the USB flash
memory device in MP3, WMA or
AAC*
formats. Depending on the
format, the display shows MP3,
WMA or AAC when a USB flash
memory device is playing. The USB
flash memory device limit is up to
700 folders or up to 65535 files.
*: Only AAC format files recorded
with iTunes are playable on this
audio unit"
My question is How do I make AAC files appear to have come from iTunes? I use FormatFactory. http://www.formatoz.com/ which rocks completely.
Any takers on this one.
If your wondering why I want AAC files instead of MP3, read this Advanced Audio Coding - Wikipedia, the free encyclopedia
AAC is smaller with better fidelity.
Old Nov 12, 2008 | 08:52 PM
cruzitude's Avatar
Have you actually tried your AAC files? Perhaps the manual is incorrect, wouldn't be the first time .
Old Nov 12, 2008 | 08:53 PM
Lemme check that our. I thought I had copied some Journey AAC files, but who knows. I'm going to try it out now.
Old Nov 12, 2008 | 09:02 PM
Nope. It says "No Song"
Hmm. I think I need to add DRM info to the files.
Old Nov 12, 2008 | 09:19 PM
cruzitude's Avatar
Is there DRM on the files? If so, remove it because the only way DRM works on the Fit's stereo is if it is played from an iPod.
Old Nov 12, 2008 | 09:54 PM
Well, actually I think it has to do with the file NOT having DRM. Weird. For now I'm just going to convert my FLAC files to MP3, 320Kb/s. I suppose that will have to do. hehe AAC is supposed to be smaller and better sounding though. I need to tak a laptop to my car to see what will work. Better than walking back and forth from house to computer.
Old Nov 12, 2008 | 10:46 PM
dtmbmw325i's Avatar
I highly doubt the radio could tell the difference between you and joe schmoe (DRM) therefore I would say that the files have to be DRM free. Anything purchased from iTunes has DRM and will not work on anything but a registered computer and an ipod. Itunes always asks for a username and password when trying to play DRM files on a new device. You can use the AAC files just strip the DRM and they will work. It is definately doable. Hope this helps!
EDIT: I meant to say that DRM free AAC files are probably doable, stripping DRM is definately doable on certain files and I cannot guarantee that AAC will work on your radio
Old Nov 12, 2008 | 11:44 PM
IfTheFoo's Avatar
There's a pretty high noise floor in a car when it's underway, are you sure you need this much fidelity?
Old Nov 16, 2008 | 03:40 AM
Ein's Avatar
Ein
I copied few gigs of AAC files from my iTune library onto a USB flash drive and they played fine in the Fit. If you are using a Mac, make sure the flash drive is formated in FAT32. Otherwise it's unreadable.
kristoffer
Jan 8, 2015 08:36 PM
splat matt
Feb 16, 2011 05:21 PM
weatherman
Apr 1, 2009 09:02 PM
Eugene.Atget
Feb 26, 2009 02:51 AM
IfTheFoo
Oct 13, 2008 03:09 PM
