Which B-Pipe
Old Dec 20, 2008 | 09:21 PM
revzero's Avatar
Which B-Pipe
With quite a few B-Pipes around such as Spoon, T1R and Megan, i'm having trouble as to which B-Pipe would be suitable with my Tanabe Concept G Exhaust.
As far as i'm concerned, the only b-pipes i know of are mentioned above including Aspec, but which in your opinions, would be the best?
I have been looking at Spoon's but i'm unsure regarding this one as where-ever i look, the description always says, 'Designed specifically/works best with the N1 Muffler.'
Does that mean, the Spoon variant only works if you have the N1, or can you use other manufacturers (Tanabe/HSK/BC/T1R) with the Spoon pipe?
Guidance appreciated.
Old Dec 20, 2008 | 11:19 PM
kylerwho's Avatar
spoon fed
the spoon b- pipe will work with any axle back exhaust that bolts up to the stock b-pipe. i would recommend the j's racing b-pipe cause there is no resinator so it flows exhaust more freely. if you are concerned with cost i would go with the t1r.
Old Dec 21, 2008 | 01:11 AM
Chikubi's Avatar
I second the J's; I've had mine for about a year and a half and it's truly excellent. I couldn't imagine being as satisfied with any other.
Old Dec 21, 2008 | 01:46 AM
Jazz GD3's Avatar
For b-pipes without resonators, it would increase in a more free flow, gaining some ponies, but by doing so, wouldn't you lose some torque?
I also plan to get a b-pipe. I would think that the spoon increases compression of the air, so there's more torque.
As I have a HKS Hi-Power axleback, the day I installed it, it felt as if a little torque was lost with the freeflowing type muffler. So i would believe adding some more a b-pipe with a resonator like Spoon's B-pipe, would increase in low end power? Especially with freeflowing exhausts like the HKS, Spoon N1, and those types?
Whatever the b-pipe though, they all have performance, but probably in certain points. This one is more torque, that one is more horsepower, some is mixed.
Old Dec 21, 2008 | 08:09 AM
junior40er's Avatar
I got Aspecs but I still need to install. I'll post what I think when I do.
Old Dec 21, 2008 | 08:51 AM
revzero's Avatar
Thanks for the input guys... I'll have a look into Js Racing one
rikell
Apr 4, 2012 03:00 AM
gmane
26
May 25, 2009 09:50 AM
jdmspoonfit
Jun 18, 2008 01:12 PM
moondog
Apr 7, 2007 11:58 PM
ChrisG
Mar 28, 2007 12:23 PM
