All rear lights went out!!
Old Dec 21, 2008 | 10:14 AM
reako's Avatar
I replaced my rear license plate bulbs with LED 194's tonight. Everything was fine for about 10 minutes then all my rear bulbs went out (license plate lights and all other rear bulbs!). I tried fuse numbers 1 and 5 (10A) but they are fine. One of the 30A fuses looks a little off, but does anyone know for sure if there is one fuse that controls all these? The owners manual explains every other fuse except for the rear bulbs.
The brake lights still light up if you hit the brakes though, and everything else I checked still works (horn, locks, reverse lights, all interior lights etc.). If I don't figure out which fuse it is by tomorrow, it will have to go to the dealer! Help!!
Here are the 194's I used:
194 Size Car LED Bulb
Old Dec 21, 2008 | 10:16 AM
kylerwho's Avatar
spoon fed
does the interior overhead light still work?
Old Dec 21, 2008 | 10:18 AM
reako's Avatar
Yep, thanks.
Old Dec 21, 2008 | 01:30 PM
HONDAMATIC's Avatar
one night all my parking lights went out like thaty, and everytime i put a new fuse it blew, i found out one of the LED license plate lights were shorting out.. replaced it and didnt happen again
Old Dec 21, 2008 | 01:54 PM
reako's Avatar
Thanks! I have since swapped out the LED's I had installed to the OEM halogen bulbs. Once I figure out the right fuse # and replace it, I guess I will just send the LED's back to the manufacturer (Oznium.com) and try Superbrightleds.com in stead (based in STL).
Old Dec 22, 2008 | 01:27 AM
HONDAMATIC's Avatar
check fuse 29, 10a under dash fuse box, it covers the parking lights, theres also a taillight relay in the fusebox..
worst case scenerio you fried the multiplex, which is the fuse box itself..
Old Dec 22, 2008 | 01:36 AM
reako's Avatar
Fuse #29 was it!!! Thank you!!!! FYI the manual states #29 is "Small light", this fuse controls the front and rear driving lights, and HONDAMATIC just saved me a trip to the dealer, thanks again for responding so quick!!
Old Jan 28, 2009 | 06:53 PM
*Garismatic*'s Avatar
You meet the nicest people... on a Honda
Old Jan 28, 2009 | 07:04 PM
concorde's Avatar
lol..
ok so reako, since replacing the fuse in #29, all is still ok?
my leds are in the mail as we speak, so i need to be prepared in case all hell breaks loose.
Old Feb 5, 2009 | 10:28 PM
reako's Avatar
Originally Posted by concorde
lol..
Yep, all good! Get a couple of 5A fuses!
Old Feb 5, 2009 | 10:31 PM
concorde's Avatar
glad to hear it! ..i've since put led's on all my rear lights, and they are working great too. thanks for the heads up.
Old Feb 6, 2009 | 12:51 AM
setter11's Avatar
heres a better ???
how did you get to replace the lights...
haha, i cant figure out how to do it :/
Old Feb 6, 2009 | 02:13 AM
HONDAMATIC's Avatar
it tells you exactly how in the owners manual
Old Feb 9, 2009 | 05:29 PM
whyzor's Avatar
I'm interested in replacing rear parking, brake, and license lights, along with front parking lights (amber) with LEDs. Which ones did you guys use or recommend? Also how is the brightness compared to OEM filament bulbs? Any pictures?
Fit4beach
Nov 17, 2021 08:03 PM
rohanks
Oct 11, 2013 02:43 PM
battouter
Oct 11, 2013 02:05 AM
Tranas
Jun 21, 2009 05:23 PM
reako
Dec 22, 2008 11:59 PM
