Help for skunk2 shortshifter
Old Dec 27, 2008 | 06:14 PM
jazzman's Avatar
I bought the skunk2 shortshifter kit.
Has anyone put this kit?
Any D.I.Y??
Old Dec 27, 2008 | 06:35 PM
kylerwho's Avatar
spoon fed
its rather simple to install.
remove center console.
4 bolts holding the shifter assembly in place.
put the adapter on the bottom of the shift lever.
place metal bushings under the shifter assembly and install longer bolts.
make sure everything is tight and shift through all the gears.
reinstall the center console and your good to go.
hope that helps
Old Dec 27, 2008 | 06:40 PM
trancedsailor's Avatar
Yeah follow the Mugen SS guide up to removing the 4 bolts holding the assembly down. Then it should be rather self-explanatory
Old Dec 28, 2008 | 10:57 AM
jazzman's Avatar
That is my problem.I cant fix the screws from the adapter on the bottom of the shift lever.
Any photo??
Old Dec 28, 2008 | 11:44 AM
fix the screws? What screws? There were 4 bolts, I don't remember any screws except for the shiftboot, the aux jack, and back of the center console.
These are 3 pics, bad quality, show me what you're talking about screws:
see the shift box, it's held on by 4 bolts. But before you get to that, you must remove the cotter pin on the left side, and the piece of steel on the forward right side. Then I think you will be able to swap levers out.
You should've just gotten the Mugen one though lol I'm so proud of it ;}
probably easier to install than the skunk2 as well. I dunno though. I hope I slightly helped, and please elaborate on the screws
Raimondas
Aug 24, 2018 01:17 PM
Octrain
Nov 28, 2010 01:26 AM
m11a1
Mar 7, 2009 12:04 PM
nitrous13
Jan 9, 2009 12:33 AM
