please help me out please
Old Feb 27, 2006 | 04:55 PM
ears182's Avatar
hi im just woundering if you guys could help me out i got a honda jazz 1.4 standard edition and me being 18 i eat at mcdonalds alot i spily coke on my sterio its the tape on built in and all it says on the screen is .1FM 0.
all the buttons workl nothing happens tho
also i tried to reset it buy unpluging the power leds behind it well what i thourght was the power lead seems to have been the airbag lead now the SRS light is on on the dash HELLLPPPP
Old Feb 27, 2006 | 05:27 PM
kps's Avatar
kps
Honda Fit Forums Moderator
Soft drinks are not good for electronics. You MIGHT still be able to save it by removing it, rinsing it out thoroughly with water, and letting it dry completely (several days) before trying it. However, the drink might already have corroded something beyond help.
Old Feb 27, 2006 | 05:35 PM
UH-0H's Avatar
coke is bad...it's so acidic...
do what that dude said
Old Feb 28, 2006 | 04:17 PM
compdooper's Avatar
Use certain water
I think using distilled bottled water is a good idea if youre gonna try to rinse it out. Distilled water will not potentially fry it, unlike tap water which is more likely to do so. I've only heard this would work and have never tried it, so best of luck.
Old Feb 28, 2006 | 11:59 PM
kentris's Avatar
I think it's best to dunk it in distilled water (as compdooper said) and let it sit for a good few while which will probably remove the coke residue built up. and then leave it to dry....and we're talking a several days, but you could speed up the process by placing it next to somewhere with heat maybe.
Don't count on it though.
Old May 1, 2006 | 04:23 PM
Daņiel's Avatar
Stop going to McDs? Or be responsible? Is this a troll?
Old May 2, 2006 | 03:06 AM
Talon's Avatar
i'm just kinda wondering why you'd be putting the coke on the dash when there is a cupholder to put it in.. Anyway...
if its' been more than a few days you probably will have to soak it in distilled but, on the same line, if it's been a few days you are probably sol.. while I haven't dumped coke on a stereo or such...I have on keyboards and other electronics and unless you get it out of it immediately it usually is hosed.
DeeDee
Jun 14, 2013 12:47 AM
Cyphron
Jan 15, 2011 11:49 PM
veteran13
Nov 1, 2009 04:37 PM
coralaholic
Sep 18, 2009 11:37 PM
Luichenwai
Nov 11, 2008 10:32 AM
