Would 205/45/16 size tires be ok on the Fit?
Old Mar 7, 2006 | 09:54 PM
tifosi360's Avatar
Would this size rub? I think 17" wheels would look too big on this car...Does any one know what is the bolt pattern and the correct offset for the Fit?
Thanks!
Old Mar 7, 2006 | 10:04 PM
BKKJack's Avatar
I can't answer any of your questions except that I have seen a Fit with 17" wheels, and they do look a little too big. Honda is offering a 16" wheel and tire option on the Fit (maybe just the Sport?). I don't imagine you could go wrong if you get the same size they will be selling.
Old Mar 9, 2006 | 06:55 PM
AJ PwR Jr.'s Avatar
Former Vendor
205/45/16 will work but if you go 17" then you have to run 205/40/17.
Old Mar 9, 2006 | 08:53 PM
dougiepants's Avatar
Avid FitFreak Poster
Lets see the 17" wheel pics on the Fit
Old Mar 9, 2006 | 09:13 PM
BKKJack's Avatar
DP: If that message was for me, I only saw the car parked at the Embassy here. If I see it again, I will try to get a photo. The wheels might have been okay, but the tires were definitely not the right size. It looked like they were trying to turn it into some sort of off-road ride, but hadn't lifted the suspension yet.
Old Mar 10, 2006 | 12:20 PM
jdmcd8's Avatar
I wouldnt go larger than a 16' on the fit, like mentioned above i think the 17" would look out of proportion..
Old Mar 10, 2006 | 05:14 PM
No I was hoping for someone else to maybe have them on their car and post them up...
Old Mar 11, 2006 | 07:17 PM
Halo's Avatar
please don't kill your fit with 17's
Old Mar 15, 2006 | 06:41 PM
edy_l's Avatar
go to the malaysian fit club forum, i think most of the people there use 17 inch rims and they got some pictures too .. after reading alot of article about them, i think 16 is the optimum size you can put on a fit..
Ed
Old Mar 15, 2006 | 11:15 PM
JazzFusion's Avatar
Jazz with 17" wheels
This is a Jazz in Norway. It's lowered 7-8 cm. up front and 4-5 cm. at rear. It runs on 17" wheels and it has an overall Type R look.
Old Mar 16, 2006 | 12:11 PM
I think that looks good
Old Mar 16, 2006 | 01:02 PM
diversity2's Avatar
I second that
Old Mar 16, 2006 | 08:10 PM
JDMGD3's Avatar
Very nice. I havent seen too many black Fit's and since that is what I ordered, its nice to see how mine would look with some 17's and lowered. But anyone getting 17's should pretty much kiss performance goodbye since on a car like the Fit that is underpowered from the factory, 17's will only make things worse from a performance perspective.
Old Mar 18, 2006 | 09:42 AM
I would like to see some DC5R wheels on it with the brake conversion... Sick!!!!
Old Mar 19, 2006 | 04:04 AM
maxrtt's Avatar
This is a pic of my Jazz with 17s on her. I running with 205-45-17.
Old Mar 19, 2006 | 08:44 AM
JDM_FIT's Avatar
im using 205/45/16 +42 offset 16x7
i dont have any rubbing issues
Old Mar 19, 2006 | 11:44 AM
mmmmm That is very good to read. I will be looking into a nice set of large show wheels maybe
Old Mar 19, 2006 | 01:31 PM
Halo's Avatar
Why would you make your car slower than it already is with 17's?
Old Mar 19, 2006 | 09:15 PM
I would only use them for cruising or shows here or there. I mean I already have RG's and SA3R's LOL
Old Mar 19, 2006 | 09:36 PM
BKKJack's Avatar
Okay, I am officially confused. I understand putting a wheel/tire combo on a car that is bigger than stock would slow the car, because you are effectively lowering the overall gearing. If you keep the overall diameter the same, are you really effecting it that much? Reducing the amount of tire sidewall will make the steering a little sharper, for certain, but isn't the amount of rubber on the tire you are removing heavier than the metal/air of the wheel replacing it? That may not be true for all styles of wheels, but is it not for others? If done correctly, can't a bigger wheel/less sidewall combination improve the unsprung weight, and thereby improve handling and acceleration?
FIT-tles Worth
Jul 13, 2012 02:34 PM
Theos92vr4
Mar 12, 2012 01:32 AM
AtticusFit
Jun 21, 2008 12:55 AM
MNfit
Mar 14, 2008 04:32 PM
hatch69
Dec 21, 2007 12:10 AM
