o2 simulator help !!!
Old Jan 12, 2009 | 07:02 PM
FELIXY69's Avatar
i have a problem with my emanage not being able to runs it's map due to the oem computer taking over.....
and it would run good for a few days and then it would run shitty for the next........
i've consulted my tuner, and he said the only solution to that is to get a o2 simulator but apparently it's illegal to have one or to sell one...
WHAT SHOULD I DO ?
can i get one in asia ?
or is there another way to solve this problem ???
thx !
Old Jan 12, 2009 | 07:23 PM
quangalang's Avatar
get rid of emanage and get something else like the ultimate or the F/IC
Old Jan 12, 2009 | 07:46 PM
FELIXY69's Avatar
i do have ultimate
Old Jan 12, 2009 | 09:08 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Have you ran a spacer on the 02 sensor? Youre talking about the secondary one right?
https://www.fitfreak.net/forums/338793-post6.html
Old Jan 12, 2009 | 09:33 PM
kylerwho's Avatar
spoon fed
which o2 simulator you looking for? the mechanical or electronic version.
Old Jan 12, 2009 | 09:39 PM
Spooling's Avatar
You should just swap in a K20
reliable and fast
you will sleep sound at night
Old Jan 12, 2009 | 10:37 PM
quangalang's Avatar
Originally Posted by FELIXY69
i do have ultimate
well in that case i dont think it has anything to do with your secondary O2 sensor. it has to be the stock ecu staying in closed loop when youre boosting.
If you had the AEM F/IC then there is a separate map for the O2 sensor so it skews the voltage that the stock ecu sees, thus making the car run on the open loop map instead of the closed loop.
for you, contact explosivepotato, he's done some work with the ultimate. he should be able to help you out.
Old Jan 13, 2009 | 03:28 AM
FELIXY69's Avatar
i am looking for something like this......heard this will help !!
O2 Simulator, E-commerce
electronic version...
Universal o2 simulator single output
Fully assembled and tested simulator.
Microcontroller based for reliability and accuracy.
Reverse voltage and short circuit protection.
Specifically designed printed circuit board.
NOT for primary o2 sensor.
Completely sealed waterproof package.
WILL NOT WORK on AUDI,VolksWagen,Porsche
Small size 1"x0.25"x0.25"
Old Jan 13, 2009 | 03:31 AM
FELIXY69's Avatar
reliable and fast
if u give me $$10000 hahaha !!
Old Jan 13, 2009 | 04:59 AM
quangalang's Avatar
so if you got this O2 simulator thing, all it's going to do is tell your ecu that your catalytic converter is in good working order. it will do nothing to solve how your car runs...
Old Jan 13, 2009 | 08:23 PM
kylerwho's Avatar
spoon fed
fooling the oem ecu with this could work but the closed loop ecu fuel calculations will cause the car to run a bit lean, but the emanage would pick up on the fuel map where the oem fails.
Old Jan 15, 2009 | 06:38 PM
07_g_fit's Avatar
Probably stupid but, I'm just wondering if anyone knows what the car is really looking for from the O2? Does it just want to see 14.7? If so why not apply 0.55V to it, while allowing your piggy-back to use a wide-band.
ZeroMotivatioN
Dec 15, 2022 07:00 PM
apexanimal
Feb 22, 2016 11:51 AM
bobblebob13
Jun 19, 2013 01:34 AM
XsteveedgeX
May 23, 2010 03:23 PM
im the fit
May 31, 2009 09:39 PM
