how to open fuse box?
Old Jan 22, 2009 | 03:20 AM
panda1314's Avatar
yes as stupid as it sounds im having difficulty opening the fuse box....are there any taps im suppose to pull or turn before i pull the cover off? the owner's manual just says "pull towards you when removing the fuse box cover". When i pull on it, it seems like its being at the top held by 3 tabs. Left/Centre/Right. The L/C came out fine but the right is fairly tight. I didn't want to pull any harder and break something.
Old Jan 22, 2009 | 03:21 AM
koolkevin1107's Avatar
i'm assuming the fuse box under the hood.... yes it has 3 tabs. They all come off the same way, u have to pull the tab opposite from the lid and lift up the cover. It's easy.
Old Jan 22, 2009 | 03:23 AM
panda1314's Avatar
my apology i should've specified which fuse box, i was refering to the one inside under the steering wheel
Old Jan 22, 2009 | 08:22 AM
Virtual's Avatar
Just pull the handle (just under 3 switch covers) and the panel swings downward. It's held in place by a few clips.
Old Jan 22, 2009 | 10:31 AM
reako's Avatar
Yeah I remember not wanting to pull that hard at first either...but the clips are designed to be removed like that so no worries...good luck!
Old Feb 18, 2009 | 11:52 PM
Superfitfreak972's Avatar
Do you pull it down or toward you??
Old Feb 19, 2009 | 12:16 AM
Tork's Avatar
both really, the top of it opens and pivots down. Crouch down just outside the drivers door and give it a tug.
Old May 12, 2024 | 03:33 PM
KwazyKwaig's Avatar
I followed the above instructions and had to pull much harder than I'd expect. One of the white plastic clips holding it in broke off. Design could be improved.
proaspen
Aug 14, 2012 09:00 PM
Neil-in-Arizona
Jul 25, 2009 02:01 AM
kyo2529
Oct 2, 2007 01:37 AM
FitLIKEaGlove
Feb 17, 2007 11:52 AM
sLiVeRwOrM
May 13, 2006 11:02 AM
