Spark plug solutions
Old Jan 25, 2009 | 08:01 PM
kylerwho's Avatar
spoon fed
i have been searching for a colder spark plug for the fit. i just now installed a set of NGK iridium IX with a heat number of 8 which is two steps colder than stock. they are plugs that are meant to go in an sr20det motor.
so if anyone has problems finding colder plugs for the fit just use the sr20det motor for your base line since there is a wider aftermarket support for this motor. hope this helps people with there search of spark plugs.
Old Feb 8, 2009 | 05:23 PM
YeeFit's Avatar
Hey man,
I used to have the NGK Iridium IX plugs with my T1R kit. I recently switched to the much cheaper NGK V-Power Racing copper plugs (heat range 8) and the car runs a lot smoother.
Just an FYI, I know u have to change the plugs more often, but the cheaper copper plugs are a ton smoother in power delivery. Ben at AJ-R recommended them to me and I don't regret trying them.
Old Feb 8, 2009 | 06:14 PM
kylerwho's Avatar
spoon fed
thanks for the info. i thought my car was running a little choppy when i put these plugs in but i will definately try the copper ones out.
Old Feb 8, 2009 | 06:46 PM
redrumm's Avatar
would the zex plugs work?
Old Feb 8, 2009 | 06:50 PM
kylerwho's Avatar
spoon fed
as long as they bolt into an sr20det head then they will work for the fit.
why zex plugs?
Old Feb 8, 2009 | 06:52 PM
redrumm's Avatar
jw cause the tunerzine fit ran them since they were colder
Old Feb 8, 2009 | 06:54 PM
kylerwho's Avatar
spoon fed
ah... i would just stick with the ngk or denso cause most those companies buy ngk or denso and slap their company name on it.
kinda like spoon plugs are really just rebadged ngk ik24.
Old Feb 8, 2009 | 06:55 PM
redrumm's Avatar
Old Feb 8, 2009 | 06:59 PM
kylerwho's Avatar
spoon fed
those look unique.
Old Feb 8, 2009 | 07:19 PM
redrumm's Avatar
they are $20.95
82003-4 Hyperformance™ Nitrous / Turbo Spark Plug - Set Of 4
Old Feb 8, 2009 | 07:21 PM
kylerwho's Avatar
spoon fed
a piece or for four of them?
Old Feb 8, 2009 | 07:23 PM
redrumm's Avatar
4 updated the info haha
ansys
Nov 11, 2023 11:41 AM
Oneoldphlaytis
Feb 11, 2016 01:43 AM
InsaneGenius
Oct 19, 2015 11:05 AM
Rollerboots666
21
Mar 2, 2015 07:46 PM
wackyflik
Oct 4, 2014 09:11 AM
