subwoofer has turn-off pop sound.. do I NEED a new HU?
Old Jan 26, 2009 | 11:47 PM
terra's Avatar
Hello! I'm a newbie here, looking for some help. I had someone install an amp and subwoofer into my '08Fit (base model). I like it, except there's a really loud POP sound about 2 seconds after I turn off the ignition. I asked my installer about that, and he said that the ONLY way to get rid of this popping problem is to get a new headunit, because the subwoofer is connected to a factory/stock stereo. Is this true?
I'm not a big audiophile, so I'm not sure about brands and things like that. He put in an 800 watt amp from Xtreme and a 10 inch subwoofer from alumapro, all for $340. Am I having this problems because of low quality parts, a poorly done job, or do I really just need to buy a new headunit?
Thank you in advance!!
Old Jan 27, 2009 | 10:22 AM
nekret's Avatar
If you disconnect the audio signal inputs to the amp does it still happen? If so its power related and you could probably fix it with a diode in line with the amps remote.
Old Jan 27, 2009 | 10:30 AM
Sugarphreak's Avatar
Push My Button
What you need is an AMP with modern technology Most of today's amps have a "soft" turnoff so you don't get that pop. You might be able to elliminate it with a small capacitor on the remote line to the amp that softens the turnoff. It would have to be tied in by running a small wire to the remote hookup and one from the ground hookup.
Old Jan 27, 2009 | 11:48 AM
koolkevin1107's Avatar
Yeah it's the amp. Higher quality brand amps have a "soft turn on" feature that eliminates the popping sound. It has nothing to do with the headunit. Ur installer is just trying to get u to buy a new headunit which is unnecessary and if he was a real qualified installer, he should know it's not the head unit and in fact the amp.
Old Jan 27, 2009 | 09:20 PM
nekret's Avatar
Shouldn't there be a way to add a soft turn off to his amp so he doesn't have to buy a new one? I'm thinking having a time delayed relay connect the amp's output to a load resistor instead of the woofer.
Old Jan 28, 2009 | 01:39 AM
terra's Avatar
Wow, thanks for the insight!
Can anyone here suggest a modestly priced amp with the soft turn-off feature?
Old Jan 28, 2009 | 03:34 AM
marz's Avatar
How about when your radio is off does it make any sound when you turn your car on
Old Jan 28, 2009 | 10:42 PM
terra's Avatar
i've tried turning off the radio/stereo before turning off the car, and it still makes that pop sound when I turn off the car.
The guys put in a toggle switch to turn on and off just the amp, and when I turn it on or off, it makes the pop sound, regardless of if the stereo is on or not.
It's making me crazy!
Clouds
Jun 29, 2013 10:25 PM
gurdain
May 14, 2010 09:29 AM
PowerHungryFIT
Mar 21, 2009 08:00 PM
setter11
Feb 10, 2009 12:59 AM
percy
May 19, 2008 03:51 PM
