Looking for pics/suggestions on tweeter placement
Old Feb 12, 2009 | 03:53 PM
davela72's Avatar
I bought a set of JL components for the front doors and am trying to get an idea of where everyone puts the tweeters.
Thanks
Old Feb 12, 2009 | 05:37 PM
Mynute 1's Avatar
Senior Member
I have a set of Infinity seperates installed in my car. I was able to install the tweeters in the factory location with a little dremel work on the metal that held the factory tweeter. The factory tweeter will just pry off from the factory piece of metal after you unscrew it from the outer garnish. If memory serves me correctly, I think I only used two screws instead of three because the new tweeter was larger and ended up blocking one of the screw holes.
Old Feb 12, 2009 | 08:47 PM
Daemione's Avatar
I'm shopping around for components (in no hurry), and was actually looking for input on the same subject. The stock tweeter locations are obviously workable, but for SQ purposes I've read that despite the drop in soundstage, it's better to keep the components as close together as possible.
There are flat(ish) spots just above the grills down in the door, I wonder if there's enough space in the panel to dremel out holes for an install down there.
Old Feb 13, 2009 | 06:08 PM
davela72's Avatar
I found this thread a few days ago: https://www.fitfreak.net/forums/fit-...omponents.html
Old Feb 13, 2009 | 11:04 PM
Daemione's Avatar
Heh, you know how I said I was in no hurry to buy speakers? oops. :laugh: I just put in an order for a set of Elemental Designs e9.65i's . . . Just hope they fit, with 78mm of mounting depth, it's gonna be close.
Oh yeah, also ordered ed's 4 channel amp & their little 10" shallow mount sub to go with them. I'm finishing the head unit & xm installation tomorrow, as well as prewiring for the amp. Whenever it gets warm enough, I've got 30 pounds of sound deadening mat and 10 pounds of closed cell foam to install as well - all via Elemental Designs.
I hadn't seen that thread, thanks for the link . . .
I'll probably buy a roll of painters tape, and spend a a few days sticking the tweeters to different spots. See what I like the best. And I just obtained a cheap (read: free) laptop from my Dad - looking into some easy to use spectrum analyzer software & a decent mike for it, hopefully tune the whole setup just right for only a few dollars.
Old Feb 14, 2009 | 11:21 AM
khanhdom's Avatar
fiberglass it if it doesn't fit....lol
Old Feb 14, 2009 | 03:15 PM
davela72's Avatar
Khanhdom, very nice set up bro!
Old Feb 15, 2009 | 05:53 PM
Daemione's Avatar
Your setup looks great, but alas, my fiberglassing skills are only adequate (at best) . . . Glassing up an an enclosure to take the place of the spare tire is within my abilities, but only because it'll be hidden by the false floor.
If I'm desperate for mounting depth in the fronts, I'd be more comfortable using a dremel to carve the plastic grills completely out of the door panel, and then mounting my own grills.
jnesselroad
Apr 16, 2011 04:38 PM
NipponFit
13
Dec 21, 2010 09:49 PM
constructicon
Mar 29, 2009 09:29 PM
tstan7777
Aug 17, 2008 12:10 PM
brek
Nov 20, 2007 04:35 PM
