header gasket
Old Feb 14, 2009 | 08:48 AM
FELIXY69's Avatar
header gasket
few questions, while tuning today we blew the exhaust manifold gasket...
is the OEM one metal ??
how much is a replacment and how much will it cost including labour to replace
i have T1R turbo kit....so it might be harder !
thx
Old Feb 14, 2009 | 11:53 AM
sevenaprils's Avatar
Nice ride, for starters. Loved seeing the progression on the build.
Anyway - I have zero experience with the turbo setups out for the Fit, but my presumption would be that the gasket should be the same for the turbo manifold as it is for the regular or aftermarket headers. With that said, bernardiparts.com or collegehillshonda.com should have what you need pretty reasonably priced, or your local dealer.
You may be able to find one cheaper aftermarket too.
Bernardiparts.com has a replacement gasket for 7.71, plus whatever shipping will be. Should be an easy install too - I hear replacing the headers on the GD is pretty straight forward.
Old Feb 14, 2009 | 07:10 PM
FELIXY69's Avatar
18115-PWA-004ViewGASKET, EX. MANIFOLD (NIPPON LEAKLESS)$7.23....but shipping is $35......
Old Feb 14, 2009 | 07:14 PM
kylerwho's Avatar
spoon fed
the exhaust gasket for the fit is a calapsable metal gasket. they are rather hard to blow. i think you probably just didnt have the bolts tightened enough.
i think someone is pulling your leg on this one.
if it blows you will see exhaust leaking under your hood.
to relpace it all you have to do is take off 3 bolts and 2 nuts to the turbo manifold. pull the manifold back far enough to slip the gasket off and put on a new one.
when you install the new one latter it with white lithium grease. the lithium will burn and turn to carbon forming a solid seal all the way around so no gas will escape.
Lyon[Nightroad]
Feb 23, 2011 01:09 PM
Polish
21
Jul 11, 2009 11:15 AM
quangalang
21
May 17, 2008 04:10 PM
gd_shane
Apr 3, 2008 10:49 AM
kancerr
17
Sep 28, 2007 03:54 AM
