Mfactory Racing Flywheel
Old Feb 16, 2009 | 10:02 PM
polar_bear's Avatar
Smile Mfactory Racing Flywheel
MFactory Racing Flywheel
It weight 9lb compare to Fidanza Aluminum Flywheel which weight 7lb.
Which one is better for daily drive ?? Anyone have the Mfactory flywheel ??
Review ??
Thanks
Old Feb 16, 2009 | 10:18 PM
redrumm's Avatar
i know someone has the fidanza. good find
Old Feb 17, 2009 | 12:02 AM
Spooling's Avatar
Which shop are you taking it to? perhaps you should shed some light and i'll join you.
Old Feb 18, 2009 | 10:46 PM
polar_bear's Avatar
No one knows anything about it ??
Old Feb 18, 2009 | 11:45 PM
redrumm's Avatar
doesnt seem like anyone wants to rip apart the tranny to put it in
Old Feb 19, 2009 | 12:31 AM
kelsodeez's Avatar
UNBANABLE
ill put mine in one day hahaa
Old Feb 19, 2009 | 04:19 AM
revd34's Avatar
i thought you had a fidanza flywheel
Old Feb 19, 2009 | 11:18 AM
kelsodeez's Avatar
UNBANABLE
yea i do. i thought you guys wanted someone with the fidanza to weigh in with a review of it so there could be a comparison.
Old Feb 19, 2009 | 04:34 PM
Tofuman's Avatar
if you go too light on the flywheel, won't revs drop too quickly and you'll have to speed shift all the time?
Old Feb 19, 2009 | 04:52 PM
solbrothers's Avatar
stock flywheel is best for daily driving
Old Feb 19, 2009 | 07:27 PM
spoonek4's Avatar
Review ??
Thanks
I'd prefer something not too light. 9lbs(4.1kg) flywheel will be the lightest I will go in Fit's L15A or any B16/D15 or D16 motor. These motors are just too small for a super light flywheel. I had a 9lbs flywheel setup in my civic EM1 before which is justttttt OK for daily driving going back & forth between home & work. Of course they do help when I went lapping event with it but how often can I rev up to 8000rpm in every gear!?
polar_bear & 1wayfit if u want info & help locally regarding to clutch & flywheel installation check out the link in my signature.
Old Feb 19, 2009 | 07:31 PM
TheImmortal's Avatar
yup
lightweight flywheel is like using a $100 scalpel to spread butter...that $0.50 cheapie is best for the mundane
is sol pronounce "soul" like the embodiment of our consciousness or "sall" like the sun? (hope it's the later)
Old Feb 19, 2009 | 08:04 PM
Spooling's Avatar
I'd start with LSD, FD, and ratios before changing the flywheel.
Old Feb 20, 2009 | 03:10 AM
Originally Posted by TheImmortal
yup
sol as in honda del sol. honda del sol brothers
Old Mar 24, 2009 | 05:08 PM
revd34's Avatar
did you ever buy and install this? my friend told me to get the mfactory because i'm supercharged. he explained to me that any boosted car is good with a lightened flywheel but not to light.
Old Mar 24, 2009 | 05:13 PM
royalflush313's Avatar
Anyone know the stock GE8 flywheel weight?
And the mfactory one fits the GE8 right?
Old Mar 23, 2010 | 11:52 AM
raja_kerbau's Avatar
what anyopne thing's if my Fit has use HKS turbo kit, i want to purchase Mfactory close ratio transmision + LSD + Flywheel? i need information....i use daily....i think not urgent to change Final gear.....have some sugestion or idea?
Old Mar 23, 2010 | 08:22 PM
spoonek4's Avatar
I'm checking with the guys at MFactory.
raja_kerbau: Can u find out whether or not your car runs a stock 4.0 final drive set? What kinda boost are u running? Reason I ask is if u run a high boost setup & drive on highway a lot then it's not such a good idea to use a bigger final drive/tighter gear ratio. Limited Slip Differential is a MUST though. It's always nice if the power is transferred to the ground efficiently. So nice clutch, LSD & nice tires are very important.
Old Mar 23, 2010 | 09:20 PM
JamesBizzle's Avatar
I'd recommend to just get an LSD.
Old Mar 23, 2010 | 09:37 PM
spoonek4's Avatar
Depends if his car runs a 4.29 final drive like the USDM Fit or a smaller setup like the JDM ones. If it runs a 4.29 setup then he can get away with just a LSD. If it's the JDM setup then I will definitely recommend him to get a bigger FD to add even more response on acceleration.
