turbo and supercharger
Old Feb 24, 2009 | 08:04 PM
porkchop's Avatar
can u have a turbo and supercharger and have like 5 boost per
would that work since they work differntly
Old Feb 24, 2009 | 08:16 PM
MNfit's Avatar
You can but I dont think you can do it on the Fit
Old Feb 24, 2009 | 08:33 PM
porkchop's Avatar
hmmm u might be able to i dont think it wouldnt fit in the new ge8 theres a lot of room in front of the engine
Old Feb 24, 2009 | 08:35 PM
kelsodeez's Avatar
UNBANABLE
yea, i think you would run into a problem with room in the engine bay if you wanted to do a tc/sc setup. unless someone figured out how to mate a roots type supercharger to the engine. that would free up tons of room. what to do is to have a supercharger that boosts in the top end and have an oversized turbo. the supercharger would help spool up the turbo then take off.
Old Feb 24, 2009 | 09:18 PM
kylerwho's Avatar
spoon fed
it would probably me more effective just to run a twin sequential turbo setup.
a supercharger would max out psi when spooling up a larger turbo so you couldnt get the big boost you wanted.
the fit can only handle 15psi max on stock internals anyway.
Old Feb 25, 2009 | 12:36 AM
Spooling's Avatar
are you sure about that? after seeing the 700whp s2000 on stock internals, i think that l15 can hold up to 20psi.?
Old Feb 25, 2009 | 12:54 AM
kelsodeez's Avatar
UNBANABLE
yea but s2k engines come with forged internals. i dont think the fit does.
Old Feb 25, 2009 | 01:52 AM
kylerwho's Avatar
spoon fed
yes im positive. skunk2 ran the fit motor all the way up to 21psi and the motor blew up. they were running 15psi as a safe setting for track runs. the fit internals cannot handle that pressure like the other honda motors.
Old Feb 25, 2009 | 03:22 AM
Fa1's Avatar
Fa1
psi doesn't mean anything by itself. a gt42r at 15 psi is a big difference compared to a t25 at 15 psi.
Old Feb 25, 2009 | 08:56 AM
NIGHTHAWKSI's Avatar
tuning is a bitch when twincharging.
Old Feb 25, 2009 | 09:01 AM
040501912's Avatar
the more psi u put in, the less the age of the engine .... 15 psi last for 1 year of running every day may be LOL!... while 5 psi will last u for quiet sometimes...
Old Feb 25, 2009 | 01:32 PM
redrumm's Avatar
i doubt it would last a year at 15psi on the fit daily
Old Feb 25, 2009 | 05:46 PM
porkchop's Avatar
this is my daily driver so just a turbo will be fin and run it at like 7 psi or 10 maybe
Old Feb 25, 2009 | 09:31 PM
polaski's Avatar
VW was playing with the idea a couple years ago. They put a small roots blower on it with an electric clutch that only engaged at initial WOT, and once the exhaust had spooled the relatively large turbo the airflow would override the SC's boost with a one-way valve, computer would shut down the roots clutch, and boost came solely from the turbo.
Top end power, no boost lag. Lots of parts.
porkchop
Mar 1, 2009 04:16 PM
danger69
13
Jan 16, 2009 03:37 PM
tonyd3773
Jul 26, 2008 03:43 PM
tonyd3773
Apr 12, 2008 12:34 PM
tonyd3773
Mar 12, 2008 04:40 PM
