DR21 15x7 10mm offset
Old Mar 23, 2009 | 11:11 PM
allgocrx's Avatar
Ok I saw a thread awhile back about the low offset drags. Im curious if I have a small drop (progress springs) will I rub or do I need extended studs?
Old Mar 24, 2009 | 02:38 AM
Fitftw's Avatar
with a 10mm offset. i think regardless of being on stock suspension or not you'd rub. but i may be wrong
Old Mar 24, 2009 | 09:26 AM
solbrothers's Avatar
unless you run retarded camber, you will rub all day. and even with camber, you will have issues
Old Mar 24, 2009 | 01:04 PM
redrumm's Avatar
the springs wouldnt look good with the low offset since they dont sit that low.
also i think those are discontinued
Old Mar 24, 2009 | 01:49 PM
jim@tirerack's Avatar
Former Vendor
They are correct. A 10mm offset wheel is going to stick out past the wheel well.
Old Mar 24, 2009 | 02:45 PM
allgocrx's Avatar
I think im gonna order them and make them fit. I'll just roll the fenders and pull them alittle. I plan on ordering coilovers right after the wheels. There not discontinued just on some sites they have to special order them. Does anybody have pictures of them on a fit?
Old Mar 24, 2009 | 03:27 PM
redrumm's Avatar
there is a guy selling some on the FS section.
they would probably fit better than the 16x8 +15 sportmaxx wheels that felixy has
check hondamarketplace they usually have good deals on these wheels
Old Mar 24, 2009 | 03:33 PM
Former Vendor
You can always make things work. You would need a fender lip roll, more negative camber and stay on the narrow side for the tires.
adam s
Mar 17, 2024 07:58 PM
SikxChoi
Jan 13, 2010 02:51 AM
bebop.fey
Mar 3, 2009 05:53 PM
1500cc
Aug 16, 2008 04:04 AM
rvall004
May 20, 2008 04:08 AM
