injen sp1511????
Old Apr 13, 2009 | 01:14 PM
im the fit's Avatar
injen sp1511????
how do I convert this intake into short ram?
Old Apr 14, 2009 | 12:35 AM
im the fit's Avatar
bump!!!!!!!!!!!!!!!
Old Apr 14, 2009 | 09:18 AM
redrumm's Avatar
cut it or something
Old Apr 14, 2009 | 10:11 AM
im the fit's Avatar
Well im not going to cut it but it says it can also be short ram
Old Apr 14, 2009 | 12:28 PM
redrumm's Avatar
did you try removing the rubber stuff? i saw that too where it says it can be short ram
Old Apr 14, 2009 | 12:37 PM
Sugarphreak's Avatar
Push My Button
It should just pop arpart, it is a 2 peice CAI. Once you have the coupler between the two pipes off you should be able to slide on the filter.
Why do you want to go to short ram? Too much water right now?
Old Apr 14, 2009 | 03:06 PM
im the fit's Avatar
I just wanted to know, I thought it would be a perfect fit but it isnt because the filter is bigger than the pipe
Old Apr 14, 2009 | 11:36 PM
TurboManGT's Avatar
Duct tape duh!!!
JK
Old Apr 15, 2009 | 10:51 AM
M@lew's Avatar
If it's the one I used to have, just use the first part + the pod to make it a short ram. To make it a CAI, add the rubber bit + another metal part with an arm type thing then the pod. If you look at it and think about it in steps that'll make sense.
Old May 25, 2009 | 09:03 PM
suketoborudo00's Avatar
if that is the one you got, the silicone part (that goes inbetween the two pipes) has a Injen logo on one end. That logo should be on the bottom end according to the installation manual picture.
Just installed it today to see how good it is compared to my PRM..
Installing took FOREVER!!
Ciggy
Oct 16, 2012 11:29 AM
Farther
Nov 14, 2010 01:33 PM
Fitguy07
Apr 28, 2009 11:45 AM
kurtdesch
Sep 26, 2006 02:21 AM
C2AUTOSPL
Jul 20, 2006 07:22 PM
