What is this?
Old Apr 28, 2009 | 08:11 PM
cbs1013's Avatar
What is this?
Anyone know what this is and its intended purpose? I just noticed it when I was checking my oil.
Old Apr 28, 2009 | 08:44 PM
Tork's Avatar
every car I have ever had has a serial number stamped on the firewall or a serial number plate.
Since the Fit has such a plastic and sheet metal shrouded firewall they give you an access panel. So it it what it says. Never shined a flashlight in there cause I am 98% sure this is correct.
Old Apr 28, 2009 | 08:48 PM
spaz27a's Avatar
Yup jus slide that sucker over and take a look! Don't worry you wont hurt nething
Old Apr 28, 2009 | 09:17 PM
FireFox91's Avatar
I figured it would be self-explanatory. But the frame number is located behind that panel. If you are looking for it, you found it. Other than that, the compartment does not have another purpose. Unless you want to hide some "stuff" for your "friend". LOL
Old Apr 28, 2009 | 09:29 PM
Boba Fitt's Avatar
OK, related question: why is this gap in the cowling (the one in the center of the constrained picture below)?
Old Apr 28, 2009 | 09:44 PM
cbs1013's Avatar
Interesting, I did not know about frame numbers I just knew about the VIN.
Old Apr 28, 2009 | 09:47 PM
cbs1013's Avatar
I guess it is glaringly obvious what it is.....kinda thought it might have been a feature for another market. Like maybe a plate there instead of a plastic "dummy panel"
Old Apr 28, 2009 | 10:16 PM
Tork's Avatar
I think it is room so the panels can slide into each other for removal.
And I should know this because I had that whole cowling apart when I changed springs. But being ADHD I concentrated with tunnel vision on the springs and i FORGOT to check that,
Old Apr 29, 2009 | 11:32 AM
Blackout's Avatar
ADHD is awsom...... LOOK AT THE BIRD!!!!!!!!
Old Apr 29, 2009 | 02:28 PM
Codger01's Avatar
I noticed that gap yesterday whilst cleaning the windscreen. Probably there because of flexing of the cowl/front end. Plastic being more brittle than steel, the put the gap in to prevent the plastic from shattering. Looks a bit daff, though!
m_x
Feb 4, 2015 03:50 PM
dennison
Jan 14, 2013 04:16 PM
melissa
Jul 5, 2011 08:41 PM
hjb613
Jul 15, 2010 07:11 PM
gynosis
Jun 8, 2009 03:07 PM
