Removing glove compartment?
Old Apr 30, 2009 | 01:36 AM
hqly's Avatar
My passport slipped to the back of the compartment. MAnual doesn;t explain how to remove compartment. Can anyone help??
Old Apr 30, 2009 | 02:13 AM
heymikesays's Avatar
1. open your glove box
2. squeeze the uppermost areas on the side together and allow the glove box to drop
3. watch the stuff you have inside fall to the floor mats
there's also (I think 2 or 3?) screws underneath. should completely come out if you can't find your passport doing the above
Old Apr 30, 2009 | 02:19 AM
hqly's Avatar
Thanks for info.. I tried squeezing the side but my box wouldn;t drop so nothing fell on the floor. I look underneath and saw a soft panel, so i bent it and wala... passport is stuck right there! awesome!
Old Apr 30, 2009 | 02:57 AM
koolkevin1107's Avatar
another way would be to unbolt the two bolts holding the glovebox up. Take a look up above the glovebox and u will see 2 gold colored bolts. U remove those 2, and the glovebox will drop down.
Old Apr 30, 2009 | 03:46 AM
1coolride's Avatar
at 1st when i read the title, i thought you wanted to remove it for weight reduction hahahaha
Old Apr 30, 2009 | 01:17 PM
docjim2's Avatar
Easy to remove: try to change the compartment air filters in my 2000 Accord!
Does anyone know if there is a compartment under the hood like the Accord to pop out and remove the leaves, branches etc that get stuck behind the filter when changing
Old May 1, 2009 | 01:08 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
techguyone
Jan 16, 2017 04:19 PM
morganti
Dec 11, 2012 02:02 AM
12vltfrk
Jan 20, 2012 02:57 PM
Fit4Spl
Jul 5, 2011 09:16 AM
hqly
May 1, 2009 10:07 AM
