speaker upgrade
Old Apr 20, 2006 | 12:31 AM
vtecboost's Avatar
speaker upgrade
Anyone here change the speakers in the car yet just wanted to know howmuch depth is there thanks
Old Apr 20, 2006 | 03:27 AM
vividjazz's Avatar
Someone that Posts too much
Around 69mm with the biggest spacers that will fit. Any deeper and you can't get the door trim back on.
Old Apr 20, 2006 | 12:29 PM
Jonniedee's Avatar
I was told that the interior space in the NA Fit's doors is different because of the side impact reinforcments - would that effect speaker space too?
Old Apr 20, 2006 | 04:12 PM
5 Zigen's Avatar
yeah i think NA and Aus has diff standard
i will be installing some Alpine Type S speakers back onto the car soon...hopefully they will fit
Old May 5, 2006 | 03:01 AM
vtecboost's Avatar
thanks so much ill be trying to fit eclipse componets which are about
2 7/8 in depth i hope i can get them too fit ill keep everyone posted.
Old May 28, 2006 | 10:52 AM
buttahball's Avatar
please do
I'll be really sad if my Utopia Be No.7's don't fit cuz of the depth.
Old May 28, 2006 | 07:27 PM
p11wrg's Avatar
I don't know how your USDM Jazz speakers are mounted but our European ones are clipped in with a giant metal spring clip. Once removed, it reveals a upside down teardrop shaped cut out in the metal panel that clear the stock magnet.
Problem we had with our install was not so much the depth of the speaker but the width of the basket/magnet behind the speaker. Our original replacement speakers just would not fit without huge amounts of cutting to the metal to make a normal 'round' hole to clear the magnet.
In the end, we had the use a less expensive speaker just to make cutting to a minimal. Note, 'cutting to a minimal' we still had to cut it and bend it slightly! We are taking pics of the build as we go along and will post up the full build pics when we are done, sometime next week.
As to front side clearance, you can get about a 1" spacer on the speaker but you may need to trim the inside of the door panel where the speaker perforations are, as there is a ridge around it, that will give you another 1/6-1/4" more clearance.
Al.
Old Jun 22, 2010 | 01:31 PM
viperjh16's Avatar
my aound suck any one used baffles do they work im thing about it sound has no bass to it
Old Jun 22, 2010 | 02:33 PM
Fit4Spl's Avatar
Here is a pic of the mids from my component set, they are spec'd at 68mm mounting depth. And yes I had to use a trim ring to get it so there was no window smacking.
http://www.jbl.com/resources//Brands...G4_800X600.GIF
FITment
Dec 28, 2010 10:11 AM
mdbrich
Jan 10, 2009 02:52 PM
jhoprodie5
Sep 19, 2008 08:50 PM
lilcat
Jul 2, 2007 01:14 AM
Mervby
Jan 16, 2007 07:54 PM
