NRG EPAC Voltage Stabilizer
Old May 9, 2009 | 10:44 PM
storm's Avatar
has anyone tried one of these and do they work... thanks
Old May 10, 2009 | 02:00 AM
Sugarphreak's Avatar
Push My Button
Falls more under the modifications category rather than ICE
You have a lot of reading to do;
https://www.fitfreak.net/forums/fit-...le-thread.html
Without re-animating this issue (has been beat to death) basically as it stands now there is yet to be an independently tested result and people are divided on if they work or not.
Old May 13, 2009 | 05:08 PM
storm's Avatar
why not ice?
i was looking at a stablizer for my audio amps. that would be ice?
Old May 13, 2009 | 05:50 PM
713_fit's Avatar
no one uses that in the ICE world...
it sound like a capacitor?
why not just get a bigger better battery..higher output alternator...bigger wire sizes....
Old May 16, 2009 | 07:01 PM
storm's Avatar
stablizer
why would you not want something that kept the voltage stable.bigger wire,big battery,and large alt. means better current. i am new to car audio,but not new to audio. it just seams the more you can do to keep your amps. happy the better.. i am running three amps one digital for subs and two class AB for front and rear...the ele. in my fit is not the best for hi end audio, but i try to do the best i can....if you know something that will help i am all about that.....thanks for responding....storm
Old May 17, 2009 | 08:14 PM
713_fit's Avatar
i dont know?
if it were useful..im sure people that does car audio competition...would use it?
from all the systems i seen and i been in the car audio scene for a while..i dont know everything..but i know a good handful.....i never seen a stablizer before....
or unless its there but they just dont talk about it..than i dont know?
Old May 18, 2009 | 07:43 PM
storm's Avatar
thanks for help
i am always amazed that you can get as good as sound as people do in a car.. my back ground is in touring audio and recording studio..i don't want to compete in car audio just want great toons...i was blowen away by all the car audio stuff.it has come a long way sence the last time i looked....what i have sounds good but i think it can be better.as i stumble through car audio world i am learning alot....people like you help ...thanks storm
Old May 18, 2009 | 08:35 PM
AtticusFit's Avatar
hand one on my hatch, i think it was more for looks than anything...
Old May 18, 2009 | 10:10 PM
Push My Button
The stabilizer you are looking at is more of a gimmicky power making device for the engine, not really specific to audio applications and the specs can vary from manufactures which leaves it in the air as to what they actually do.
The other big thing is you want to isolate your engine & car electronics as much as possible from your audio equipment for optimum sound quality; the installation location of this device is going to defeat that intent.
You can get much more affordable (and proven) devices for your audio. I would suggest you use a capacitor to give you a solid 14V power source at peak draws.
As for noise, you can use a ground loop isolator for your lines to pull any noise you might get from the engine out. Try to install it as close as possible to the amplifier so you don't get any other noise into the lines from outside sources.
They are hella cheap and you can get them anywhere.
Ground Loop Isolator - RadioShack.com
Another good way is to buy expensive insulated/isolated lines, they go a long way to helping reduce any interference that can get into them. The biggest thing is just makes sure your lines are running as far as possible from other operating car electronics and hot wires.
DarkPuppy35
Oct 22, 2012 01:43 PM
Vash
May 8, 2010 11:56 PM
whoa42
Aug 19, 2009 11:21 AM
ERICSPANTS
Mar 21, 2009 12:55 AM
revzero
Jul 9, 2007 12:04 PM
