A/C makes Knocking Sound in Warm Weather
Old May 13, 2009 | 03:32 PM
jjnasution's Avatar
I bought a 2008 Honda Fit last winter. I just realized as the weather is getting warmer, the A/C makes knocking sound every time I turn it on. It only happens when outside temp is higher than 80. I am planning to take it to dealer since the car is still under warranty but I am wondering if others have similar issues.
Thanks
Old May 13, 2009 | 04:04 PM
your a/c makes some noise when it turns on/off... so you're saying it's a different sound than when it was with the defroster turned on? cause the a/c turns on while in the defrost mode.
Old May 13, 2009 | 04:16 PM
jjnasution's Avatar
When it's warm, if I turn on the a/c or defroster, the knocking noise will come interminently. When it does, the a/c does not blow cool air. My first thought was the compressor, but it seems the sound is coming from the firewall area.
Old May 14, 2009 | 10:27 AM
vtakthis's Avatar
im having the same exact problem? is there a fix or can i just take it to the dealership, my fit does have a salvage title is it still under waranty??
Old May 17, 2009 | 04:35 PM
Steeldog's Avatar
Try just running the A/C during the winter months. Oh, wait a minute...
Old May 17, 2009 | 11:13 PM
doctordoom's Avatar
Supervillain
salvaged vehicles are no longer covered by honda's warranty. but the a/c is supposed to make noise so unless it's a LOT of noise or the a/c isn't working, there isn't really a problem. also, the noise you guys are hearing might just be the a/c kicking on and putting more strain on your engine at idle speed.
Old May 19, 2009 | 03:42 PM
HypnoFit's Avatar
Angry A/C noise
Re:07 Fit ~ My a/c compressor has been making noise since last summer but every time I bring it to the dealership, no noise. What else is new?
Old Jun 19, 2009 | 12:38 PM
jjnasution's Avatar
The dealer found out that there is too much freon/pressure in the compressor. The warm wether cause them to expand even more pressure making the knocking noise to the compressor. In this case, I was lucky the compressor is able to witstand such amount of pressure.
The dealer evacuate and recharge the compressor according to spec. Problems solved.
Old Apr 12, 2019 | 07:14 AM
ChunkE's Avatar
Please let this be the answer
I have been parking my 2007 Fit sport for the last 2 summers because of this. Please let this be the fix.
ommegga
17
Dec 9, 2018 06:03 AM
inspire007
Jul 10, 2014 08:23 PM
nodelock
Oct 25, 2012 05:43 AM
toomuchjoy
Jun 10, 2012 09:31 AM
coldstorage5
Jul 31, 2006 10:29 PM
