Caliper Clearance
Old May 21, 2009 | 02:14 AM
bigtoepfer's Avatar
Caliper Clearance
I tried a search and returned nothing. I don't have time to take the wheels off right now to measure so i was wondering if anyone knew how much space we need to clear the calipers minimum. from the hub. I'm looking at a custom set of aluminum rims but they have 1.5" for caliper clearance. And i don't want to have to run spacers. So if anyone knows offtop what it is that would me amazing thnx.
Old May 22, 2009 | 04:27 AM
HONDAMATIC's Avatar
i think if it fits integra, you should be okay
s
thats my clearance
Old May 22, 2009 | 12:13 PM
GD3_Wagoon's Avatar
damn, that looks like a single millimeter of clearance
Old May 22, 2009 | 12:14 PM
bigtoepfer's Avatar
yeah. But that doesn't really help me much. becaues i don't know what the integras need and still don't know what i need LMAO
Old May 26, 2009 | 07:29 PM
mahout's Avatar
We use 1/8" (3 mm) for minimum clearance. Otherwise small pebbles can get lodged in the crevice. Pebbles bigger than 1/8"tend to bounce off.
Old May 27, 2009 | 12:03 AM
bigtoepfer's Avatar
you mean as long as the face is more than 1/8" from the hub. Or 1/8th inch from the caliper. See what i am trying to figure out is that a set of wheels i want has clearance for 1 1/2 inches from the hub face. So as long as the caliper falls in there some where. I'm good. I guess i'm not quite explaining myself appropriately. lol
Old May 27, 2009 | 01:43 AM
danielg's Avatar
I would suggest to take measurements. I don't know off the top of my head, and I would hate for you to get wrong information.
I will say though, in terms of JDM custom wheels - You run a standard disk in the front and low in the rear.
Old May 27, 2009 | 09:25 AM
bigtoepfer's Avatar
Oh cool. I always wondered what those "disk" things meant. Thats good to know
Old May 27, 2009 | 12:41 PM
Fit4Trav's Avatar
The disk type coordinates with the type of brakes you have.
Correct me if I am wrong danielg
Old May 27, 2009 | 01:01 PM
mahout's Avatar
No I mean a 1/8" rod will fit between the spokes or any othe part of the wheel or suspension at any point of the wheel travel and all parts of the caliper. The length of the rod is not important, just that it fits anywhere and everywhere. The photo appears to have too little clearance..
I haven't figured out what dimension you are measuring but possibly you mean a cylinder 1.5" thick from the hub face. Don't know if that will clear the caliper; a quick unofficial check says it won't Needs more like 2.5 to 3" near as I can tell, and maybe as much as 4".
Old May 27, 2009 | 01:03 PM
danielg's Avatar
disk is the how thick the hub is. Thicker the hub, higher the caliper clearance. for example you need a Race disk for a huge ass 6 pot caliper. I have a 17x9 +11 here that has like a 1 inch lip, due to the thick hub. If you are running drums or what not, you can run a extremely thin hub to maximize lipage.
Hope that makes sense.
Old May 27, 2009 | 01:12 PM
bigtoepfer's Avatar
I need to make sure that the space of A in the second picture is less than 1.5 inches. I am about to order a set of custom wheels. That once made or mine whether they fit or not. And he said that the wheel will have 1.5" from hub to face where the caliper needs to fit in. If this perhaps makes more sense. I understand what you are saying about the 1/8" clearance needs but that does not answer my question. I guess i'll just measure myself when i get a chance. so we can be sure. But thanks for checking.
lister
Nov 2, 2012 12:27 AM
Kingfisher
Feb 1, 2011 09:43 AM
thewatcher101
Aug 4, 2010 01:59 PM
5lilangels
Nov 22, 2009 08:26 AM
trancedsailor
Jul 16, 2008 02:43 PM
