one low beam headlight out
Old May 31, 2009 | 10:49 PM
urbnzeus's Avatar
The low beam of the right head light is out but the left one works. Both of the high beams work fine. Can anyone help?
Old May 31, 2009 | 10:51 PM
Black01's Avatar
Change the bulb
Old May 31, 2009 | 10:53 PM
Black01's Avatar
Old May 31, 2009 | 11:13 PM
urbnzeus's Avatar
are you sure its the bulb? wouldnt both the hi and lo beams go out then?
Old May 31, 2009 | 11:17 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
It can happen H4 bulb has separate filament.. change bulb problem solve.
Old May 31, 2009 | 11:27 PM
Black01's Avatar
Yes change the bulb but I would recommend changing both bulbs so you'll get the same beam of lights. Also while you're in the process, try not touching the glass part of the bulb.
Old Jun 1, 2009 | 07:57 PM
jimrb66's Avatar
change bulb
Hi
I always wear thin rubber gloves when changing blubs,than no worry of touching glass.
Jimrb66
Old Jun 1, 2009 | 10:26 PM
Julio's Avatar
change the bulb but don't increase the wattage!
IQBALLK
Oct 29, 2024 12:36 PM
mav238
Jan 14, 2015 02:59 PM
JDMxGE8
May 18, 2010 12:29 PM
phunklife
23
Mar 17, 2009 10:55 PM
xonexlifex
Nov 26, 2008 06:45 PM
