Metra 40-HD10 Antenna Adapter Question
Old Jun 25, 2009 | 02:00 PM
vwli's Avatar
I recently installed an aftermarket HU on my 2009 Fit Sport. It is having a lot of static when I am listening to FM radio. I wonder I hooked it up correctly or not. On the Metra 40-HD10 antenna harness, besides the regular antenna cable, there is another wire. I connected it to the HU wire labelled "antenna power supply". Did I do it correctly?
Old Jun 27, 2009 | 03:51 PM
MetalHead88's Avatar
yes you did. the blue wire from the harness goes to the power antenna lead on the headunit. we dont have power antennas, but they are "amplified" check the connections make sure that the plug is all the way into the headunit.
Old Apr 2, 2011 | 05:47 PM
Dave23703's Avatar
I'm really glad you posted this, It took a long time and a lot of "just deal with it not working" answers. I believe I have corrected those who have said that you don't need the power connected.
Old Apr 2, 2011 | 10:42 PM
thaduke2003's Avatar
^ What he said. As long as the new radio isn't junk, there shouldn't be a noticable increase in static- if anything, with a decent aftermarket unit, there should be less!
Whenever you do a relatively simple swap/"upgrade" of any kind, and something stops working the way it should, always check your work. I keep a plaque saying something like that in my shop- 9/10 times, it's correct Mark W.
Old Jun 7, 2011 | 09:28 PM
WeaponR23's Avatar
where is the blue lead? do you mean the remote blue for like amps?
Old Jun 8, 2011 | 09:42 AM
funkbucket007's Avatar
Your Pioneer (based off your other thread) harness should have a blue wire and a blue/white wire. The blue wire is the power antenna lead (which is what your blue wire on the antenna adaptor connects to) and the blue/white is amp turn on.
Old Jun 8, 2011 | 07:10 PM
WeaponR23's Avatar
I only have a blue/white wire from my harness (Pioneer)
Old Jun 8, 2011 | 07:14 PM
I can technically use that as well for the antenna.
Old Oct 4, 2013 | 07:43 PM
boydb1212's Avatar
Ok I feel really dumb right now im trying to put this adaptor on but I cant even find the stock fm wiring from the car can any one show me a pic or give me so directions on where to find it or what to do thanks
NjBlazin07
Feb 15, 2020 05:20 PM
WeaponR23
Jul 28, 2011 05:06 PM
Rod2Rice
Jul 22, 2010 11:47 AM
vwli
Jun 25, 2009 09:41 PM
GodSpeed
Jun 19, 2009 04:24 PM
