Rear shoulder belt won't stay put!
Old Jul 13, 2009 | 02:36 PM
Chairman Kaga's Avatar
This is just a minor annoyance, but I wonder if anyone has found a good solution. The rear shoulder belt, which I have never used, continually drops down from the ceiling mount where it lives while not in use, and dangles there in my rear view. It's just a little distracting. No matter how tightly I jam the thing in there, it won't stay for more than a day or two. Any tips for making it stay?
Old Jul 13, 2009 | 02:48 PM
Hootie's Avatar
/learn 2 corner
Really, if you (or at least for me) take a turn too sharp/fast the belt will pop out of its slot. One solution I seen somewhere on this forum is where a member removed the plastic slot and I believe they bored out the hole that the belt clips into.
I'll see if I can find the thread for you...
...here you go.
https://www.fitfreak.net/forums/fit-...g-out-fix.html
Old Jul 13, 2009 | 02:51 PM
^^^ aha!
Old Jul 13, 2009 | 02:56 PM
gd3vbp's Avatar
Originally Posted by Hootie
This. I did this because mine was doing the same as yours. Nothing to do with cornering, everything to do with the metal clip being loose. I popped it out of the ceiling and there was no tension on it.
Old Jul 13, 2009 | 03:05 PM
Awesome. Assuming it's not 112 again this evening, it'll be done by dinner.
Old Jul 14, 2009 | 04:36 PM
Hootie's Avatar
I haven't done this and more than likely will not because like I said, my center belt usually pops out on a spirited drive. Mind you, the only thing that really is loose on the holder is the section that holds the seat belt's clip and that always slides out a little; but if I jam the smaller clip into its hole it stays in place rather well.
Old Jul 14, 2009 | 06:01 PM
somdamon's Avatar
Mine fell out once. I discovered you need to insert the metal latch (as if you were buckling the seatbelt) until it "clicks" (latches in place).
Old Jul 14, 2009 | 07:58 PM
Cat's Avatar
Cat
Just like somdamon said if you insert the metal latch it will normally stay put. Since 2007 mine has only slipped out twice.
Cat: x
mikejet
Sep 22, 2021 11:04 PM
Marrk
Apr 11, 2017 10:52 PM
GotFitB13
Dec 14, 2014 03:53 PM
hazzard
Nov 20, 2013 01:38 AM
