Stock Dunlops Tire Life
Old Nov 9, 2009 | 04:27 AM
xonexlifex's Avatar
Exclamation Stock Dunlops Tire Life
ok so heres my problem, how long does the stock dunlop sp31as tires last? i have about 34k on the tires now and have no idea if i need to change them out, ive been getting crappy milage and drive aggressive all the time. should i get a set of new tires? i drive almost every day and i put on atleast 150 miles on the tires every other week when i make up the trip to my fiances house. ive been noticing its getting rougher and worst handling ever. i just thought the tires had atleast a 50k warrenty on them just bec they are good tires. it also felt like there was a flat spot in one of my tires or something because when i drive really slow it feels like the car dips when it gets to a certain part of the tire. i got the car in 07 so the tires are already 3 years old. someone please help!!!!!!!
Old Nov 9, 2009 | 08:05 AM
Selden's Avatar
Just because tread hasn't worn to the wear bars doesn't mean that tires shouldn't be replaced. If you don't like the Dunlops, change them.
Old Nov 9, 2009 | 09:08 AM
alvarospatchez's Avatar
I changed mine a couple of months ago. Lasted 31-32k miles. I went with same size Kumho Ectsa ASX. Really like them a lot better. I've been a long time Dunlop fan, a new set of shoes always feels better.
Old Nov 9, 2009 | 11:25 AM
baldddguy's Avatar
I just changed mine after ~50,000 miles. I needed to change before it snows here. (2007 MT Sport)
Old Nov 9, 2009 | 11:51 AM
xonexlifex's Avatar
damn so u actually got 50k out of them. Did u drive aggressive at all? Bec i drive pretty aggressive going to chico and to work everyday just bec u have to be with all the stupid drivers out there
Old Nov 9, 2009 | 12:32 PM
baldddguy's Avatar
I've been known to drive aggressively at times. Ohio has its share of stupid drivers too.
Old Nov 9, 2009 | 12:40 PM
xonexlifex's Avatar
So how much longer should i wait to change my set?
Old Nov 9, 2009 | 01:50 PM
secondspassed's Avatar
If they're not even worn down nobody can tell you but you.
Old Nov 9, 2009 | 03:02 PM
xonexlifex's Avatar
heres what i have, i did the penny thing and i can see lincolns head so does that mean i need to change them
Old Nov 9, 2009 | 11:04 PM
doctordoom's Avatar
Supervillain
judging from your pics, it's about time to change your tires. do you see that wear bar near the bottom of your pics? it's in the circumferential groove in the tire tread. that wear bar indicates that you're getting near the end of the tread's intended life. you can look up "wear bar" online if you aren't that familiar with tires yet. but basically, it's almost exposed, and it's intended to be used as an indicator of when your tread has worn down to the point that you need to get new tires.
Old Nov 10, 2009 | 12:28 AM
xonexlifex's Avatar
Ok well it looks like i need tires. Thats ok bec i want wider ones anyway. Better handling here i come
Chris Norlund
Jul 29, 2015 10:40 AM
Goobers
21
Nov 13, 2011 07:04 PM
Eugene.Atget
Sep 12, 2011 09:26 PM
jcfit
Mar 26, 2011 03:37 AM
sharkey
Mar 31, 2009 11:12 AM
