AT rough running/stalling in "R"
Old Nov 24, 2009 | 07:26 PM
Fit of RAGE's Avatar
who else has had this issue??
1) Start the vehicle up in the mornings.
2) Warm it up for about 30-45 seconds
3) Put the car in "R" and teh RPM drops from 1300 to 500. Car feels like it's about to stall. Check engine light is NOT on. According to my scan tool, the "Calculated Engine Load" is 87.7%!!
- Torque converter????
Has anyone else had this issue?
Old Nov 27, 2009 | 05:47 PM
Koi's Avatar
Koi
I've had my car drop in rpm and actually stall/die when put into Reverse before. It was due to a vacuum leak from the intake manifold, the hose was cracked from the inside out, so it didn't look like it was leaking until I took it off and checked. Might not be the problem you're having, but every time my car starts stalling/dying when at idle or changing gears, I've found it to always be due to a vacuum leak at 2-3 different possible inlets.
Old Aug 1, 2010 | 12:40 PM
denise's Avatar
resolution? others have this problem?
This just happened to my 07 fit sport this morning. did you have any resolution to this, fit of rage?
anyone else have this? know what the problem is?
Going to have it checked out tomorrow, want to be informed.
thanks!
Old Aug 1, 2010 | 02:52 PM
Still haven't found the cause. I did notice that it happens more when the weather is colder.
Old Aug 2, 2010 | 08:14 AM
denise's Avatar
stalling
thanks for the reply. it happened again this morning as i was going to take it to the shop. felt like it would stall but then caught and i backed up, put it in drive and it stalled. also did it yesterday at a stopsign - didnt fully stall but didnt catch right away.
do you - or anyone - have any other problems you think may be related? how do you like the car in general? this is a newish vehicle for me...
07 fit sport 75000 miles
Old Aug 2, 2010 | 09:21 PM
SilverBullet's Avatar
Ive had that problem too. Engine running rough and wanted to die at idle. I had a manual trans. My father in law also had this problem with a Chrysler and nothing found at dealer. Did you just get gas? My FIL just got gas and next morning it kept stalling and he was leaving in a few days to get back to his home in Georgia. Its the nitrogen in the gas covering the spark so you get a miss with stalling. It just annoying and should go away after engine warms up.
I would change your trans fluid, but don't think thats the cause.
bwb
Jul 19, 2025 01:56 PM
SparkyFox
Nov 17, 2014 11:30 AM
Marrk
Sep 20, 2013 11:07 AM
eddyksurfer
Apr 7, 2013 11:02 PM
DrKelso
May 17, 2010 06:54 AM
