Raising the rev limiter?
Old Nov 26, 2009 | 02:40 PM
dewthedew's Avatar
Other than hondata how can it be done?
Old Nov 26, 2009 | 03:34 PM
secondspassed's Avatar
take apart your gauge cluster and make your numbers go to 11.
Old Nov 26, 2009 | 04:01 PM
rvall004's Avatar
i think hondata is the only solution.....give them a call and see what they can do..since you have the the kit up to 10 psi plus the 310 cc injectors
Old Nov 26, 2009 | 04:19 PM
JDMchris.com's Avatar
I run THIS
you want to up it even more?
Old Nov 26, 2009 | 06:54 PM
dewthedew's Avatar
I dont have hondata im running an aem f/ic + rsx 310cc. hiboost came out right after i started running that.. I asked if i could get hondata without the injectors and KW said no. My current setup is running great id just love the 7100rev limit.
Old Dec 2, 2009 | 03:36 PM
JRios's Avatar
What about an Emanage Ultimate?
Old Dec 2, 2009 | 04:43 PM
kylerwho's Avatar
spoon fed
try contact top fuel. they have a retuned jdm ecu that bumps the rev limit up to 7400.
the problem with the usdm ecu is the firewall so reflashing is expensive. the jdm ecu doesnt have the same firewall problem so they can be tuned.
or perhaps you can go with a stand alone to create whatever parameters you want.
Old Jan 28, 2010 | 10:42 AM
ku8o's Avatar
have u ever remap ECU ?
some of us here do
without piggyback...
rev limit to 7000
davidteddiilin
Mar 26, 2012 05:54 PM
jazzista
European Fit Forums & Clubs
Oct 7, 2011 04:06 AM
manuelgbn
Feb 16, 2011 02:56 PM
Daemione
Sep 17, 2010 02:55 AM
Feinkosta
Feb 14, 2009 01:01 AM
