Trying to Help a Friend: No 12v Outlet?
Old Dec 11, 2009 | 02:20 PM
Sean33's Avatar
Hi FitFreaks.
I'm trying to help a cluless friend with a 08 Fit and she tells me there is no 12v accessory outlet under the cap just a plastic filler.
Is this true, that some of these cars ship without accessory outlets?
Second are these outlets plug and play if you buy the harness or do you have to wire it all the back to the fuse box/engine bay. I've never looked at her car before.
I did a few searches but I couldn't find an exact answer other than everyone wants a 12V outlet in the rear.
Thanks for the help,
Sean
Old Dec 11, 2009 | 03:48 PM
Uncle Gary's Avatar
I can't speak for all Fits, but the outlet in mine works. I just went out to the garage and checked it. Of course, it's only "live" with the key in the "on" or "accessory" position.
Old Dec 11, 2009 | 04:03 PM
Sean33's Avatar
I don't think it's a matter of if it works. It sounds like the actual outlet is not in there. Its just a plastic tube instead of the outlet. That seemed very suprising to me.
Old Dec 11, 2009 | 04:40 PM
TurboManGT's Avatar
I have an 08 Sport and mine is functional
Old Dec 11, 2009 | 04:55 PM
seeremlive's Avatar
There should be a metal outlet inside the plastic tube. If not then if you have a warranty take it in. Sounds like it got missed in assembly.
If it was a used car you will have to pull the center console and see if the wires are there. if they are, go to the dealer and get the part and install it. It just snaps in and then clips to the wire.
If the wire isn't there, well then you have to run a new wire to power and make sure it is fused (or install a fuse inline) but you still have to buy the socket from Honda to clip into the console holder.
To run one in back just tuck the wire under the carpet from front to back removing the sill plate at the door bottom. Cut a hole in the panel where you want it and install an outlet (with or without cover the auto parts stores carry both for under $15) and you are home free. Just make sure to connect the center of the outlet to + (positive) and the outside to - (negative).
Old Dec 11, 2009 | 05:08 PM
TurboManGT's Avatar
Does she have the JDM center console? You have to switch out the outlet when you do the install.
Old Dec 11, 2009 | 06:43 PM
Sean33's Avatar
Hey guys thanks for the help. She brought her car over and I realized she wasn't pushing in the her adapter far enough so she thought the 12v outlet wasn't working or wasn't there. jeesh, women.
Thanks,
Sean
Old Dec 11, 2009 | 06:53 PM
Perrenoud Fit's Avatar
jeesh
That'ns going to be high maintenice, good luck! sean
Oneoldphlaytis
Jan 12, 2016 11:28 PM
SilverEX15
Aug 13, 2014 06:52 PM
MarcoM
Jan 5, 2011 08:23 PM
hogsniper
Mar 13, 2008 06:22 PM
benlinus
Nov 21, 2007 12:36 AM
