2009 Fit Sport non-nav stereo - LF Speaker Lost it's Bass!
Old Dec 16, 2009 | 01:58 AM
digitaldan1987's Avatar
I've had my FIT for about 4 months now, and the other day I noticed that my stereo didn't sound right; the left front speaker seems to have lost it's bass completely! It sounds just like a tweeter (the tweeter on the dash is still working normally as far as I can tell, just the door woofer seems screwed up.) It doesn't sound blown out or distorted, just has no bass at all.
We just got our first dusting of snow, and the temperature dropped pretty rapidly, so I'm wondering if that may have had something to do with it?
Anybody have a similar problem? Is there some kind of crossover connected between the tweeter and woofer that could have shorted?
Old Dec 16, 2009 | 11:50 AM
runbikerun's Avatar
My LF speaker has had an occasional bass grumble in the last week. It will sound like it is blowing out for a minute then return to normal. I have been blaming the cold too.
Old Dec 16, 2009 | 05:41 PM
Actually since you mention that, that did happen to me. I thought nothing of it because it did go back to normal at the time. I just noticed yesterday that it wasn't normal.
Do you have the black 09' fit sport M/T also?
Old Dec 16, 2009 | 05:44 PM
runbikerun's Avatar
I have a Black 09 Sport auto. I wonder if anyone else is having this issue?
Old Dec 16, 2009 | 05:45 PM
Check out this post from another thread https://www.fitfreak.net/forums/fit-...html#post94064
Did you by chance get yours from Troy Honda? I'm gonna wait a bit and see what I can do to diagnose it myself without taking apart too much before I call them up.
Old Dec 16, 2009 | 08:29 PM
runbikerun's Avatar
Mine actually came from Bloomfield Honda. I really hope the issues you found on that 06' post were solved. I'll have to listen more closely to that speaker.
Old Dec 16, 2009 | 08:36 PM
Selden's Avatar
Your car should still be under warranty; use it. Warranty is one of the benefits of paying top dollar for a new car, rather than buying used.
Old Jan 18, 2010 | 07:58 PM
waxyourboard's Avatar
Your speaker's blown. That simple.
Old Jan 18, 2010 | 11:41 PM
hspatz's Avatar
My left front speaker did exactly the same thing that I confirmed when I turned it on alone. It was a very cold night, around 10 degrees. I found if I turned the volume way up, it would start, then distort, then die again. Then after 2 or 3 days, it worked normally again, as it does now. I wonder if some water made it into the door and froze, then melted, allowing it to work. I sometimes lower the window for better visibility in snowy conditions when looking left. This might allow water into the door in the speaker area. This is only a guess.
mdsniper7
Feb 13, 2012 01:47 PM
Ciggy
Oct 16, 2010 01:36 PM
accordguyintake
Jun 6, 2010 03:09 PM
accordguyintake
Feb 1, 2010 01:46 PM
pip_rocks
Dec 13, 2007 08:36 PM
