Strange Clicking Noise when I run the Intermittent Windshield Wipers
Old Dec 21, 2009 | 04:39 PM
exosymbolic's Avatar
I bought my Fit less than a month ago, and recently I've been hearing a clicking sound when I run the intermittent wipers (lower the right paddle one notch) or when I do a quick wipe (raise the right paddle one notch).
I hear the noise in the upper left area of the dash board when I first select either setting, and then each time the windshield starts up again (if running intermittently). Not sure if this has always been the case, but the sounds seems new to me.
Has anyone else heard this noise? Should I take the car in to get inspected? It's rather annoying and noticeable.
Thanks!
Ben
Old Dec 21, 2009 | 08:00 PM
gimme's Avatar
Master FitFreaker
may just be a relay.
Old Dec 21, 2009 | 08:05 PM
Relay?
Thanks for the reply, Gimme...can you tell me more about what a "relay" means?
And just to clarify, then noise is in response to flipping the paddle. It's more of a single click than an ongoing clicking noise.
Old Dec 21, 2009 | 08:07 PM
grtpumpkin's Avatar
Its your right turn signal, please, for the love of man-kind, turn it off! LOL Take it back to the dealer, this is what the warranty is for...
Old Dec 22, 2009 | 05:41 PM
Jessh's Avatar
I hear the same noise each time the wipers move. It's a soft click. I just assumed it was normal. Let us know if you take it to the dealer and it's something that needs to be repaired.
Old Dec 22, 2009 | 09:03 PM
SupermanGolfer's Avatar
Hear same sound in my 09 Fit, just assumed it was normal. Everything seems to work fine.
Old Dec 22, 2009 | 09:39 PM
Olyar15's Avatar
It is the relay. Nothing wrong with your car. A relay is an electromechanical device that allows a small current to control a larger current. When a relay switches from "off" to "on," it makes a slight click. Whether you hear that noise depends on where the relay is located and how much sound deadening there is in a car.
Martha Campagna
Nov 28, 2018 09:35 PM
pipcorona
Jul 16, 2014 06:10 AM
GC617289
Dec 13, 2010 10:10 AM
