gd springs on ge?
Old Dec 25, 2009 | 11:18 AM
fitisbamf's Avatar
gd springs on ge?
i was wondering if gd springs fit on a ge and if they will lower the car? and if lowering springs for a gd will work on a ge?
Old Dec 25, 2009 | 12:04 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
do a search it's been done before and it works.
Old Dec 25, 2009 | 12:16 PM
fitisbamf's Avatar
i did but i think i typed in the wrong thing bacuse i didnt find anything on it... but ill try again
Old Dec 25, 2009 | 12:23 PM
gimme's Avatar
Master FitFreaker
it works, and it actually lowers it a bit.
Old Dec 25, 2009 | 12:33 PM
fitisbamf's Avatar
ok so the stock gd springs lower the car? what about after market gd springs? they lower the car about 1.5 in for the front and 1.4 in for the rear. how low would that make my ge?
Old Dec 25, 2009 | 12:37 PM
gimme's Avatar
Master FitFreaker
you would need to find the thread where the person did a side by side with the GD springs vs the GE stocks. Once you find how much the gd's drop it, then you can figure in the actual lowering springs i'd suppose. But, if you are lowering it anyways, might as well use one's GE specific unless you're looking to go lower than what is offered.
Old Dec 25, 2009 | 12:55 PM
fitisbamf's Avatar
well some1 said it lowers it about 20mm so thats roughly .7 in. with that added to the drop of 1.5 in. it will drop it a little over 2 in.? hahah my ge will look so low if it does
Old Jun 13, 2010 | 04:31 AM
OO978's Avatar
just confirming that the GD springs are lower than the GE springs comparable side by side, however upon installing them they turned out to be exactly the same height. whether they need to settle in or not, 2hrs after the install the height remains exactly the same as the stock GE springs.
just wanted to clear it up that it doesnt drop it 20mm over the GE springs
Old Jun 13, 2010 | 01:49 PM
fitisbamf's Avatar
probably cuz they are stiffer but i did put lowering springs for a gd in my ge and it lowered it more then 1.5.... so idk hahah
pearl
Jan 15, 2016 03:33 PM
Maty J
May 19, 2013 01:15 AM
kiggs
13
Apr 28, 2010 10:12 PM
Spaded
Mar 29, 2010 03:10 AM
Lek
Jun 30, 2009 07:50 AM
