WRX TD04 turbo L13a CVT
Old Jan 5, 2010 | 08:23 PM
trinisir's Avatar
So I have been researching on potential turbos to use on my l13a CVT setup. Read on several site/forums that the TD04/TD035 turbo is ideal for the Fit. I have the opportunity to get one off a WRX. I read that the spool up time is between RPM 2500 to RPM 5000, but i'm not sure.... should I go for it?
Your opinions and comments are appreciated.
Old Jan 5, 2010 | 10:33 PM
Type 100's Avatar
TD04s are generally good for small-displacement engines like our L13As; they work well even with D15Bs.
My only concern is your tranny. The clutch packs on GD CVTs get fried quite easily at 120 WHP - they're not really suited for turbo applications.
Otherwise go for it - especially if you can source a manual gearbox somewhere.
Old Jan 7, 2010 | 09:48 AM
trinisir's Avatar
Actually turns out it's not a WRX but an STI, so the turbo is not a TD04 but a VF30 none ballbearing...so I guess that's that. =(
Old Jan 9, 2010 | 08:48 AM
trinisir's Avatar
Found a turbo from a Mitsu. Libero. It's a TD04L for US$ 220. However, I have been strongly recommended to use a CT9/CT9b turbo off a Toyota Starlette... Opinions and comments would be greatly appreciated .
Old Jan 12, 2010 | 12:02 PM
DatFIT's Avatar
Finding TD04 isn't hard... fairly cheap. Since i'm a subie owner. I see them going for 100$ in forums... But too bad I don't have mine anymore. Sold it, since I changed my turbo.
Old Mar 5, 2010 | 01:15 PM
jazzista's Avatar
Would be interested in learning how to tune the ECU after doing all the piping, etc.
Old Mar 5, 2010 | 03:35 PM
kennef's Avatar
good luck, sounds interesting!
Old Mar 5, 2010 | 05:07 PM
413FIT's Avatar
On my old hatch(d15b7 motor) I had the TD04L turbo, it spooled very quick and loved it.
Old Mar 5, 2010 | 09:43 PM
TOOL's Avatar
You can find td04s with no shaft play for 100$ easy. I wouldnt pay more then that.
Old Mar 6, 2010 | 05:27 AM
jazzista's Avatar
Would you mind PMing me where can I?
TIA
Old Mar 22, 2010 | 08:21 PM
jexeffectz's Avatar
^I'll find one for you...for a finders fee
Old Mar 23, 2010 | 03:55 AM
jazzista's Avatar
...Ace!
Thank you.
yangjiesheng
36
Aug 20, 2009 10:54 AM
alphaseinor
30
Jul 27, 2009 09:04 PM
tonyd3773
Jul 26, 2008 03:43 PM
tonyd3773
Apr 12, 2008 12:34 PM
tonyd3773
Mar 12, 2008 04:40 PM
