Offset???
Old Jan 10, 2010 | 12:20 AM
SikxChoi's Avatar
Offset???
Whats the best offset so the wheels wont rub fenders and lowered? +40,+45,+48?
Old Jan 10, 2010 | 08:00 AM
FITMugen's Avatar
Not enough info. It depends upon wheel and tire size. Usually, you will need +53 offset (but it is hard to find). However, I saw FIT owners installed +42 and above offset.
Old Jan 10, 2010 | 03:04 PM
Fitting's Avatar
Depend on drop and wheel/tire size but you can run the 40. You can go even lower if you willing to roll/pull the fenders.
Old Jan 13, 2010 | 02:51 AM
xonexlifex's Avatar
i have a set of 205/50/15 tires on a +35 offset wheel and it rubs, if u stick with a 195 and go with a +45 offset wheel it wont rub at all, unless ur dropped then i dont know, im on stock springs and the back rubbed on every bump, so i had to shave the back fender and roll the metal fender and put rubber spacers in the springs just to make it not rub if i had anyone in the car or had people in the back
adam s
Mar 17, 2024 07:58 PM
Adam_Melton
111
Apr 16, 2023 10:12 PM
HB1320
Feb 14, 2009 01:09 PM
sbualuba
Jan 31, 2009 02:04 PM
rvall004
May 20, 2008 04:08 AM
