how to wire a sub
Old Jan 12, 2010 | 05:01 PM
DENRACING's Avatar
Angry how to wire a sub
hey guys hope you all are doing great. well i have a 911 situation. i got my self a sub and had it connected a few months ack. now my sub doesnt work and when i looked around the fuse box i saw a blue wire that was pretty much hanging around and i am confident that its the (rem) wire and can someone please help me with connecting it somwhere.
Old Jan 12, 2010 | 05:26 PM
larshnordli's Avatar
If you have an amp to the sub i'm pretty sure it is labeled "remote" or just "rem", and the other end should go into your head unit. Do you have a picture/brand and modelnumber to the amp/sub and/or head unit? if you are unsure of HOW to connect the cable, post a picture, and maybe it'll be easier
Hope this helps!
Old Jan 12, 2010 | 05:28 PM
DENRACING's Avatar
the side of the amp is all connected and i have the oem headunit. im sure it was connected right but the REM wire that is supposed to connect to the head unit is off. so basically i need to find out where to connect tit and how to reach it
Old Jan 12, 2010 | 06:05 PM
shazaam's Avatar
can hook it up to basically whatever fuse you want it to enable with afaik. goin off of blackfit07's writeup the 2nd #10 fuse runs when the key is on II so you could go there if you want n the amp will be turned on then.
https://www.fitfreak.net/forums/fit-...honda-fit.html
cuteboi's diy for ya too - https://www.fitfreak.net/forums/fit-...-fit-usdm.html
sk8pw1
Jun 9, 2010 10:12 AM
Wahe
Apr 14, 2010 09:36 AM
whoa42
Sep 4, 2009 09:56 PM
ShannonHonda.aka.Fit
Jan 2, 2009 03:16 PM
cKranez
Jun 16, 2008 08:00 AM
