dc sport header install question
Old Feb 24, 2010 | 03:15 AM
kevinkidstar138's Avatar
am i suppose to use all the oem hardware, they sent bolts btw
and
what size exhuast gasket do the 07 fits use?
any help would be great
Old Feb 24, 2010 | 10:39 AM
isthata_scion's Avatar
Yah use the new bolts. the 2 top studs did not come off when i took the stock header off ( i hear sometimes they do) so I just reused the 2 nutts that went over those. if they come off, i guess you can use 2 new ones. i also reused all the gaskets.
PB blaster and a breaker bar saved me fyi.
Old Feb 25, 2010 | 05:17 PM
grtpumpkin's Avatar
Depends on how old your motor is. II put my header on when the engine had about 36,000 miles, so the OE gasket was in fine shape. Defineately use the new mounting hardwire, no sense re-using the old stuff if you have new. The only tricky part may be the hard mount at the bottom of the header where it meets the OE stuff, start those bolts before you tighten the header bolts.
tr-yama
Nov 20, 2011 12:13 AM
Padraic
Apr 14, 2011 04:01 PM
Padraic
Dec 8, 2008 04:51 PM
kifu
Oct 26, 2007 02:45 AM
Raaaaaaaaaay.
59
Feb 16, 2007 03:07 PM
