Sponsored by:
Sponsored by: CARiD
2010 Fit Weekend Warrior
Old Mar 31, 2010 | 02:51 PM
RogueFit's Avatar
Just to start I love everything about my new fit. I used to go up to the canyons here in arizona to run through the twistys up there and wonder if I can make the fit great for running in the canyon on the weekends and still maintain the stock suspension. I wanted to get input on if strut bars are worth it and what exactly I will get with them. I will also be replacing the stock dunlop tires with real tires to get some more grip. Not necesarily worried about speed just want to maintain the speed in the corners without sacrificing the ride quality. Thanks for everyones opinions.
-Tyler
Old Apr 3, 2010 | 03:54 PM
Evotech8's Avatar
Tires, alignment, and rear sway bar if you want to maintain the stock suspension and ride quality. These made the biggest difference on the stock susp setup.
Don't forget brakes are important too for canyon runs. Good set of pads and brake fluid are a must.
Old Apr 3, 2010 | 04:45 PM
RogueFit's Avatar
I am looking into upgrading the stock rotors. Is this going to give a big boost in the stopping distance. I notice a lot of people using the integras slotted rotors but I am seeing some online aswell. Any inputs on which rotors to go with? Slotted, drilled, or drilled and slotted. Thanks again.
-Tyler
Old Apr 3, 2010 | 05:52 PM
Evotech8's Avatar
If u upgrade to bigger rotor/calipers then yes it will improve your braking performance substantially.
The past cars I had slotted, cross drilled, dimpled rotors it did nothing to improve braking performance. But they did look sexy behind the wheels though.
heres a topic on bigger brake upgrade:
https://www.fitfreak.net/forums/fit-...tallation.html
Old Apr 4, 2010 | 02:35 AM
RogueFit's Avatar
What about doing that upgrade on a GE8? Thats just for the gd
Old Apr 4, 2010 | 03:10 AM
JJIN's Avatar
to optimize down hill touge with stock sussy you have to remove your rear seats, ss brake lines, better brakes(bigger rotors maybe two piece for weight savings and better heat dissipation, bigger calipers with better clamping force. if not just upgraded rotors and sports pads with better brake fluid), lighter wheels, proper alignment.
imo i wouldnt run a rsb on a street car since lift off mid corner can cause snap oversteer during max driving.
Old Apr 4, 2010 | 03:13 AM
crash001's Avatar
I got a c piller bar and it helps u in corner and hi speed driveing it take the wobble out of mine
Old Apr 19, 2010 | 03:01 PM
cr4zy3lgato's Avatar
damn... it must be amazing driving the fit in these conditions!
If you want better handling, a rear sway bar is your best bang for the buck! you can also put a front strut to even things out... if you're going to change your rotors, don't go with drilled... slotted are'nt bad because they eliminate the risks of glazing... but it's still pretty useless... just go with a set of plain brembos... for the tires, go with a higher speed rating... i changed from S to H and it feels a lot better! but you can even higher!
timemachine
Jun 23, 2014 10:23 PM
fit_in_somerville
Dec 18, 2011 04:37 PM
BIGSAMV
Sep 9, 2011 08:25 PM
Fitguy07
Apr 11, 2011 09:23 PM
broody
Car Shows, Events, and Racing
15
Aug 31, 2010 08:46 PM
