Wagner Replacement Rotor Screw Holes
Old Apr 23, 2010 | 05:22 PM
bsvidito's Avatar
My Wagner replacement rotors (BD61982) don't have the 2 screw holes in them and my old ones had them. Is this an error by Wagner? Thanks
Old Apr 24, 2010 | 07:36 PM
Carbuff2's Avatar
Not to worry, the countersunk screws were there to hold everything together during vehicle assembly.
It is not absolutely necessary to have them (as long as the wheels are there to keep the rotors from falling off)
PS, the OTHER threaded holes COULD be needed later on, as they are there to help remove the rotors by screwing bolts bolt into them. Do the Wagner rotors include those at least?
Old Apr 24, 2010 | 09:14 PM
bsvidito's Avatar
No screw holes in Wagner Rotors
Thanks for your help
No the only holes in the Wagner Rotors are 4 holes where the bolts go. It is exactly like pic below except mine has 4 holes.
Update: I went and ordered another Wagner Rotor set from a different company and received the identical ones so I installed them anyhow. I will let you know in a couple of years how hard it will be to take them off.
Old Apr 24, 2010 | 09:40 PM
Carbuff2's Avatar
HeeHee, hope you used a bit of anti-seize behind them. The A-S not only prevents corrosion, it acts as a heat sink to help rotor heat dissipate.
Old Apr 24, 2010 | 10:14 PM
bsvidito's Avatar
Anti-seize behind the rotor...never thought of that. I might as well take off the wheels now and squeeze a little bit behind the rotors.
Thanks
Hasafraker
Dec 28, 2014 10:20 PM
Thurst63
Mar 14, 2014 11:48 PM
sh00k
13
Mar 1, 2013 08:58 PM
QuackXP
Feb 15, 2010 04:48 PM
F'it_ImFromTx
41
Jul 19, 2009 09:23 AM
