Ebay lug nuts?
Old Jun 1, 2010 | 10:45 AM
cr4zy3lgato's Avatar
Ebay lug nuts?
I don't know if i should trust this, but i found forged aluminium lug nuts on ebay for less than 30$ for a set, i want to avoid the vision motorsports cause i've heard a lot of bad things about them, and most of there sellers are banned on forums unless someone can vouch for them...
The point is i don't want crap but i also can't afford high end like Kics otherwise i would have bought them immediatly... and the cheaper nuts look just like Blox but without the brand...
please if any of you guys used similar nuts i would like if you could share
Thanks!
Old Jun 1, 2010 | 10:57 AM
gd3vbp's Avatar
Don't do it. Cheap ebay lugs are cheap. I've seen them get stripped out being threaded on the very first time. All it takes is a minor over torquing and the threads are gone. Just imagine a hard corner putting pressure on them...
Old Jun 1, 2010 | 11:20 AM
lol... that's what i tought... but at the same time they looked pretty legit... just not overpriced XD
Old Jun 1, 2010 | 03:39 PM
anybody else as some input on these?
Old Jun 1, 2010 | 03:44 PM
score04w's Avatar
dont do it. Spend a little more. you get what you pay for.
Old Jun 1, 2010 | 04:16 PM
GD3_Wagoon's Avatar
$150 rays lugs are cheaper than $800 worth of suspension/body/wheel damage
Old Jun 1, 2010 | 07:11 PM
JDMchris.com's Avatar
I run THIS
Whats ur budget? Blox, Buddyclub, skunk2 can all be had for under $100. The ebay ones, depending on the ones your looking at, arent all bad. I actually run a set on my Beater fit. Have had them on for almost 2 years, taken off and put back on at least 7 times with no problems, and I drive that little beater HARD. I have the BLOX ones on my white fit and they also work really well, and I liked them because they were black chrome.
Old Jun 1, 2010 | 07:18 PM
thefit09's Avatar
I got a set of Muteki off ebay for ~$50.
Old Jun 1, 2010 | 07:36 PM
I run THIS
Also forgot to mention 949racing has some for around $50
Old Jun 2, 2010 | 01:02 AM
well i do wonder how they can possibly be that bad... most of the products are getting bad reputations because of bad users... i'm not saying that 15$ lug nuts on ebay are good, all i'm saying is that sometimes there is also a problem 18 inches in front of it too... XD
the only thing i don't like with muteki is that either come with a full set of spline drive or a regular set...
Old Jun 2, 2010 | 03:21 AM
prio's Avatar
Old Jun 2, 2010 | 03:58 AM
I run THIS
Originally Posted by prio
Chances are the OP has aftermarket wheels, and OEM lugnuts are not reccomended with aftermarket wheels.
Old Jun 2, 2010 | 05:49 AM
Type 100's Avatar
Spring a little extra for the KICS, especially if they're steel. Those will last much longer than aluminum and are more resistant to thread loosening, although a little heavier.
I have Kyo-Ei's black steel nuts and Bull-Lock wheel locks on my car now and they're way stronger than my lightweight Work RS aluminum nuts. You could round off the edges of the aluminum ones if you're not careful with your hex nut wrench - it happened to me.
Old Jun 2, 2010 | 06:29 AM
exactly, if i would have needed OEM the decision would have been easy...
mmmh... well about the kics all i've seen so far are the ones @200$+ so maybe i still have some homeworks to do
CommanderSlug
Jan 11, 2017 08:27 AM
rocketberger
19
Nov 13, 2012 07:30 AM
lowkeymods
Feb 25, 2012 02:19 PM
Spyderfenix
18
Dec 22, 2010 05:40 PM
gnarlyj3rick
Sep 14, 2010 06:38 AM
