HID Bulb Cracked in Housing
Old Jun 10, 2010 | 01:21 AM
samwell's Avatar
So I have been running an HID kit for about 3 years now and I have had no problems... until a few days ago. One of the bulbs either cracked or exploded in the housing and now there are glass shards in the housing.
What do you think the cause is???
Should I get new bulbs or a whole new HID setup???
I am assuming they are just old and need to be replaced but it was just a strange occurrence.
Thanks
Old Jun 10, 2010 | 01:38 AM
LaoSiFu's Avatar
Thanks
Sam,
Depending on your HID kit but a lot generic kit these days use very similar set up and a good chance that you can just buy there bulb. If you have a picture of the bulb and the wire (meaning you have to pull it out) post it here. Perhaps I can recommend a place where you can purchase the bulb alone.
As for all the broken shards, you can try your best to remove your headlight and try to shake it out. If you still have pieces you can't then you might have to open up your headlights.
LMK if you have any questions.
~Robert
madtodaimax
Feb 26, 2014 04:22 PM
XenithXenons
47
Jan 9, 2011 07:56 PM
kroze
May 28, 2009 11:27 PM
DrKelso
Apr 26, 2009 01:24 PM
SoccaBoi
Oct 18, 2007 10:49 AM
